350 motor what to do with it
Old Aug 7, 2006 | 10:09 AM
Swim500in5's Avatar
Car: 83 Z-28
Engine: 305 Qjet
Transmission: 700r-4
i pulled a 350 motor from a car i had sitting around old rusty camaro with a 350. now im not sure what to do with it. heres what i know so far.
10054727 its a 89-93 chevy 350
has aftermarket heads
350 carb intake and q-jet
wont turn over with a wrench
blown head gasket, collant in the oil
tranny fluid brand new
was told that last rebuild was 8 months ago
what the best plan take it apart and put it in baggies and see just what is up with it. is this a good block to build? or should i find a lt1
Old Aug 7, 2006 | 10:39 AM
Tripper511's Avatar
Car: 1982 Trans Am
Engine: 350 4BBL
Transmission: 4 Speed Manual
It would definitly be worth taking apart and fixing whatever is wrong with it. The LT1 is a better enginge but you can get just as much power with the 350 for much cheaper.
Old Aug 7, 2006 | 11:13 AM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
take the spark plugs out and see if any oil/antifreeze comes drains out. then you can probably turn the engine over with a wrench.
Old Aug 7, 2006 | 03:43 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
yeh make sure there isn't water or oil in the combustion chambers, you won't be able to turn it over if there is. Just pull the plugs and try again.
I'd probably have a machine shop refreshen the bottom end, get some new valve train parts for your heads, get a edelbrock perf rpm a/g intake, stuff a good cam in it and call it a day.
Old Aug 7, 2006 | 03:53 PM
TP355Z's Avatar
Car: 1988 Camaro SC
Engine: LT1 SBC
Transmission: LT1 T56
Axle/Gears: 3.73 Moser 12 Bolt
Everyone covered the 'checkup' stuff. My advice: Have a machine shop perform whatever services are needed (surface heads / block / bore / hone / etc). Then figure out what you want. With the stock crank/rods you can go safely up to 6,000 RPM (if you have it balanced - money well spent) so with a cheap set of heads (the new Vortecs look awesome) and a nice cam you can have an easy 400hp. Good luck!
Tyler
Old Aug 7, 2006 | 05:47 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
I've seen a coffee table made from a small block before, It was kinda neat, it really helps your trailer stand out from the rest. Just thought I'd suggest something different then everyone else.
Old Aug 7, 2006 | 06:42 PM
Keepin This One's Avatar
Car: 1988 iroc/2000 saab 9-5
Engine: 355 tpi/Roller cam
Transmission: 700r4/2800 stall,megashifter
Axle/Gears: 3;42
I would slash the coffee table idea,and do that when you find a 302 ford .
Id build the 350, send the heads out,and block like mentioned.
These are so fun to build,
Old Aug 7, 2006 | 09:50 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Originally Posted by 89RsPower!
...it really helps your trailer stand out from the rest...
~wiping beer spew off of the monitor~
now that was funny!
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
Mickeyruder
Sep 2, 2015 02:45 PM
Out-Cast
Aug 17, 2015 10:57 AM
st.evel07
Aug 13, 2015 06:15 PM
