roller to flat tappet cam change?
I have a 91 z28 with a 305 tpi,will I beable to keep the computer and everything else on the motor if I change the cam set up to a flat tappet cam istead of the roller cam and will the push rods from the roller fit the tappet?
Car: 91 Camaro
Engine: 350 tpi
Axle/Gears: crappy 3.08 open rear
why would you want to go from roller to flat tappett? if you stay roller all you have to buy is a cam, you can get a used lt4 hot cam for about $100 plus there is not as much of a headache with roller, no lobes rolling off. if you go with a big cam you will have to change valve springs, mabey work the heads, and yes to computer tuning will need to be done.
Transmission: 4L80E/4L80E
"Rough idle" and "TPI" shouldn't be used in the same sentence.
junkcltr
Aug 2, 2019 11:12 PM
ambainb
Apr 25, 2016 09:21 PM
