valve cover oil leaks...
Old Aug 8, 2006 | 02:39 PM
FullSendRacing's Avatar
Car: '85 Trans Am FAILBIRD
Axle/Gears: 4th gen torsen 3.42
So I feel like I've tried everything. Now running a vacuum pump for crank case evac - I figured that would take care of any possible oil leaks. I've tried 2 different sets of valve covers with cork gaskets. I read in another thread that the 'superseal' gaskets work well - I got those and they still leak. I took them off, cleaned them up, and applied 'aviation form-a-gasket' figuring that would have to take care of it. Still getting leaks.
I put UV dye in the oil to make sure it was the valve covers, and sure enough, that's where it's coming from.
It's only leaking enough to leave about 1 drop of oil every time I shut the car off. I need this thing to be dry so they don't laugh at me when I take it to the racetrack...
Old Aug 8, 2006 | 02:41 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Are you sure your covers are flat?
Old Aug 8, 2006 | 02:47 PM
brand new AFR heads. tried my old covers, and now have a set of nice finished aluminum covers.
Old Aug 8, 2006 | 03:20 PM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Axle/Gears: 9 BOLT/ 3.27 GEARS
Maybe there is a slighty warped surface on the cylinder head...???
Old Aug 8, 2006 | 03:34 PM
I guess the next step is to try some excessively thick gaskets like the Fel-Pro 1628. It's a quarter inch thick rubber over steel... maybe the extra thickness will allow me to tighten it some more and get a better seal?
Old Aug 15, 2006 | 01:55 PM
well the Fel-pro's are awesome. They didn't fix my problem though. Turns out my breather has a leak. it's a brand new Moroso breather that has a seam.... leaking good out of the seam any time I shut the car off.
thank you UV dye....
MoJoe
Sep 24, 2015 09:12 PM
Thaney9
Aug 29, 2015 03:16 PM
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
mustangman65_79
Aug 8, 2015 01:18 AM
