The trunk motor won't engage.
Old Aug 10, 2006 | 04:53 PM
oifish's Avatar
Car: 1992 Camaro Z28
Engine: 5.7 TPI L98
I noticed today that when I went to close my trunk the motor didn't work at all, no noise. I'm thinking the motor is shot. I know the fuse isn't blown b/c the button that opens the trunk still works. Any help is greatly appreciated.
Old Aug 10, 2006 | 05:44 PM
87gtaJOLENE's Avatar
Car: 1987 gta T/A
Engine: 5.0 TPI
Axle/Gears: 3:23
Most likely it's the motor. I had the same problem except the motor on my car still ran. Turned out the plastic gear beside the motor was chewed up so I replaced it. The motor is seperate from the gear, so I'm geussing all you need is a motor.
Old Aug 10, 2006 | 07:30 PM
oifish's Avatar
Engine: 5.7 TPI L98
Well I was messing around with it and suddenly the motor engaged again. What happened was the wire that came from the sending unit was loose. So with a little duct tape I was able to keep it in place and keep it from shaking loose. Thanks for the advice though.
1992rs/ss
16
Jan 28, 2016 09:58 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
E Rod
Aug 28, 2015 05:17 AM
87 camaro iroc
Aug 20, 2015 07:47 AM
slade5612
Aug 11, 2015 07:19 PM
