93-92 octane required on my setup?
Old Aug 9, 2006 | 03:30 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
my set up is in my signature, what do you think?
Old Aug 9, 2006 | 03:39 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
With a 10.2 compression ratio you should be able to get away with 89 octane...
Old Aug 9, 2006 | 03:42 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
you think so? I figured it would be too high... I do not want to use premium if i do not have to.
Old Aug 9, 2006 | 04:15 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I'd say premium, 91 octane. with optimal timing 36*.
Try and find out. My setup knocked like crazy on 87 octane, when I forgot once.
Old Aug 9, 2006 | 04:21 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
my motor can be only timed by ear since the timing mark doesnt show on my balancer...
Old Aug 9, 2006 | 06:00 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Good grief!
I use 91 on my 350 HO Deluxe (the manual calls for 92, but I've experienced on problems).
JamesC
Old Aug 9, 2006 | 07:32 PM
wezeles's Avatar
Car: 1982 Pontiac Trans Am
Engine: 383 stroker 4 bolt roller, juiced
Transmission: b&M th400
Axle/Gears: 4.10 with c-clip elims
well if you want the best bang for your buck your not even close... there is a reason new motors have knock sensors its to cope with the crappy gas
Compression Octane Number Brake Thermal Efficiency
Ratio Requirement ( Full Throttle )
5:1 72 -
6:1 81 25 %
7:1 87 28 %
8:1 92 30 %
9:1 96 32 %
10:1 100 33 %
11:1 104 34 %
12:1 108 35 %
no one ever runs what is best for there car except race teams...a nd the fact its hard to find anything above 93 octane in most areas...
that info came from here 7. What parameters determine octane requirement?
Old Aug 9, 2006 | 10:51 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
lucky for me 93 is common on the east coast, its what i currently run
Old Aug 10, 2006 | 09:04 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Sorry wez, but i gotta call crap on the chart you found.
If that chart is right i should be running c11/c12 race fuel, not the 91 octane i am!
Old Aug 10, 2006 | 09:15 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
How do you do that?
"Dad, does this sound like 36 degrees? " "no son, that sounds more like 38, back it up"..
How do you even tune the thing for max performance when you can't even figure out your total advance..
-- Joe
Old Aug 10, 2006 | 09:19 AM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Axle/Gears: Limited 9 bolt, 3.45
i know i know advance it till it runs like ****,, then back it down 2 degrees..
Old Aug 10, 2006 | 09:27 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I used to go by the advance it until you don't go faster or it knocks, then back down.. I blew up a nice 11 second 355 that way... But it was my fault.. You can only run so little injector before it comes back to haunt you.
-- Joe
Old Aug 10, 2006 | 03:16 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
That comp with cast heads and I would run premium.
Old Aug 10, 2006 | 07:43 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Originally Posted by anesthes
How do you do that?
-- Joe
well if you magically make a mark that would show up on a timing light and a magical timing tab to go along with it then perhaps we could get somewhere.
Bubbajones_ya
Jul 6, 2024 08:32 PM
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
customblackbird
Oct 1, 2015 04:30 PM
R13_Braz
Sep 18, 2015 05:00 PM
