radiator has a small hole... melting beads quick fix
Car: '88 GTA
Engine: L98 -350TPI
Ive got a small leak in my radiator and this guy at work told me about these small beads that you can pour into your radiator and they goto the leak and melt, covering the hole and fixing the leak. He said that autozone sells it. Have yall heard of this stuff and does it work? Thanks.
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
To weld aluminum you need a TIG welder to do it right. How many home wrenches have a TIG welder?
Tin/lead solder will not stick to aluminum.
i have a GTAW welder, which is what people that don't know any better call TIG, and i'd fall in to the home wrench group. you know there are even some forward thinking people welding aluminum with GMAW process and a few people stuck in the dark ages using SMAW and still a few others using a torch.
you're right you can't use tin lead solder to solder aluminum, but that doesn't change the fact that with the correct solder and equipment it can be soldered
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
These radiators are a dime a dozen. If you're really worried and too cheap to get a good welder to do it or to replace the radiator, then JB weld it.
Car: '88 GTA
Engine: L98 -350TPI
Thanks guys. I had heard about the stuff and didnt know how well it worked so i figured id ask. I just picked up a new radiator today so it will be goin in this weekend.
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
Car: 87 IROC-Z
Engine: POS 305
Transmission: 700-R4
Axle/Gears: DUNN0 STOCK DISK BREAK 10 BOLT
dang i just JB welded my leaky alum radiator about 2 years ago and it is still holding lol i am a cheap @$$
theshackle
Mar 5, 2017 06:37 PM
ambainb
Apr 25, 2016 09:21 PM
