Cheap Horsepower?
Old Aug 17, 2006 | 08:33 PM
Morder.'s Avatar
Car: 20 M550i xDrive
Engine: LB9 305 TPI
Cheap Horsepower?
Whats a cheap way to get more horsies?
What I've done so far:
Carb rebuild
Cat-back
New Air Cleaner w/ Filter
Old Aug 17, 2006 | 08:47 PM
85LT4Z28's Avatar
Car: 85 z28 and a 97 ford ranger
Engine: 305 carb and a 4cyl pos
Transmission: both have a 5spd
remove all the smog stuff if you havent allready... if you dont have an electric fan get one... the main thing si if you dont have to do smog or safety checks then remove the smog stuff it reduces weight and freees alittle from the motor... did you do a k&n filter on their...
Old Aug 17, 2006 | 09:01 PM
Morder.'s Avatar
Engine: LB9 305 TPI
I bought an Edelbrock Pro-Flo air cleaner and I guess it does have a K&N filter on it. But I've heard quite a few bad things about K&N, should I replace this filter?
Guess I should have read the fine print...
Old Aug 17, 2006 | 09:17 PM
85LT4Z28's Avatar
i like k&n it has always worked for me... that and it last for freaken ever...
Old Aug 17, 2006 | 09:43 PM
Bowtye101's Avatar
Car: 1991 RS/ 2006 Charger R/T SRT-8
Engine: 383 4bbl / 6.1 liter HEMI
Transmission: TCI 700R4
Axle/Gears: 3.42 posi
Pro Flow
Your eldebrock pro flow is NOT a K&N filter but if it is the foam filter you can apply the K&N oil to it to make it more effective in preventing dirt from entering your carb.
Old Aug 17, 2006 | 10:10 PM
manchesterbeast's Avatar
Car: 1985 pontiac trans am
Engine: 350 with carb and headers
Transmission: borg warner 5speed
want cheap horsies? run it without an air filter!
92centexcamaro's Avatar
Car: 92 Camaro RS
Transmission: stock
Axle/Gears: stock
Headers-$129
Intake-$100-200
Old Aug 17, 2006 | 10:42 PM
Morder.'s Avatar
Engine: LB9 305 TPI
Ah yeah I read it wrong. The triangular and oval cleaners come with K&N filters.
Will I see that big of a difference if I buy edelbrock performer manifold and some headers? Right now I have a stock 305 manifold, nothing special. Will there be a difference in fuel economy?
I have a 4 barrel carter q-jet, freshly rebuilt.
Old Aug 17, 2006 | 10:49 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
NITROUS!
Old Aug 17, 2006 | 10:53 PM
Car: 92 Camaro RS
Transmission: stock
Axle/Gears: stock
Hopefully you would see 20-50hp gain. With some tuning you would have a noticable increase in hp. Intake and headers would increase the efficency of your motor which in theory any time you increase efficency of your motor, you better your gas milage This is IF you go easy on the loud pedal. Drive like grandma and you should get better milage. Then when you want to show off or give your friends whiplash just pound the pedal.
Old Aug 17, 2006 | 11:42 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
headers and y-pipe, best bang for buck right now.
SFC's, won't make you go faster, but will make the car feel wayyy more rigid.
port heads?
Old Aug 18, 2006 | 12:04 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Originally Posted by 1991CamaroRslow
NITROUS!
We have a winner!!!
Old Aug 18, 2006 | 12:31 AM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
Fast. Cheap. Reliable. You can pick any two.
K&N filters aren't worth the money. Don't let their propaganda fool you... they flow more air than a paper filter would, but conversely they let more dirt into the engine as well. Stick with a plain old paper filter and change it when it gets dirty. It's only $10, and the life of your engine should be more important than a slight increase in airflow. The only real time a K&N filter shines is when it is dirty compared to a dirty paper filter.
The electric fan idea is a good one if you don't already have an electric (or dual electric) fan on your car. The mechanical clutch fan that came with many of these cars takes a good bit of HP to turn.
Another good idea would be to switch all your fluids over to a synthetic variety, especially the oil and rear end gear fluid. They will also reduce parasitic losses and help protect your parts better than conventional fluids would.
Reducing the weight of your car won't add any horsepower, but it will definately make it easier for the engine to push your car and will improve gas milage slightly.
Aside from this, there's not too many ways to get cheap horsepower. This hobby is all about knowledge and money. If you have the know-how, but no money you can speculate all you want on what will give your car more HP, but without the parts (which cost $$) it's all just bench racing. On the other hand, if you have a lot of money and start bolting on parts but have no idea what they do, then your engine may end slower than it actually was to begin with.
The trick is to find a middle ground where you know what parts make your car faster, and spend money on that the first time around so you get the best $-to-HP ratio.
Old Aug 18, 2006 | 12:32 AM
Morder.'s Avatar
Engine: LB9 305 TPI
I know tricks aren't free but I was thinking sub $500 range, I figured I'd still get something good around that budget. I'll go ahead and throw a pm at ya.
Anymore suggestions? Thanks everybody for stuff posted so far.
Edit: Just read your post after I typed this, you got any tips on stuff to remove to free up weight?
Old Aug 18, 2006 | 03:42 AM
Bowtye101's Avatar
K&N filters
Just don't like the idea of a lifetime filter huh you wou rather have less air flow and spend 5 to 10 bucks every 10,000 miles if you oil the filter right it will stop more dirt than any and I mean any paper filter and if K&N filters are so bad why does just about every race team use one. I guess they don't know that K&N filters are worse than paper filters. Your entitled to your opinion but remember more air flow means more power and thats the name of the game isn't it.
Old Aug 18, 2006 | 02:14 PM
Nate86's Avatar
Engine: 4 cylinder
Hmm, maybe it's because they are PAID by K&N to sport their logo on their car to advertise their product? How many NASCARs do you see with Castrol on their hoods? Plenty. Does that make it the best oil to use? Not necessarily.
And seriously man, how much HP do you think a clean K&N filter is going to give you over a clean paper filter anyway? This dude's car is pretty much stock and the heads, cam and exhaust are going to limit his HP WAY before the air filter even becomes an issue!
Old Aug 18, 2006 | 02:25 PM
Car: 92 Camaro RS
Transmission: stock
Axle/Gears: stock
Old Aug 18, 2006 | 05:22 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Check the 305 thread in the FAQ forum. 305 power increasing mods are already discussed there.
Old Aug 18, 2006 | 05:41 PM
WaaX's Avatar
Car: 1985 IROC
Engine: 350 TPI (block was swapped)
Transmission: 700r4 w/corvette servo
Axle/Gears: no idea
I would humbly recomend that you get a new intake manifold and do some at home porting of your heads, Take an intake manifold gasket, lay it over the head intake ports, take some machinist blue and blue up the metal that is blocking the intake ports. Take a die grinder and goto town.
nitrous?
Old Aug 18, 2006 | 06:27 PM
Morder.'s Avatar
Engine: LB9 305 TPI
I have a 350 though.
Old Aug 18, 2006 | 06:30 PM
systalis's Avatar
Car: 92 RS
Engine: Built 355
Transmission: Built 700r4
Axle/Gears: 3.73's w/ stock axles
500 bucks? Do headers and as much exhaust work as possible because they are good stepping stones for any future mods.
Old Aug 22, 2006 | 08:15 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
nitrous?
have u ported ur heads??? if so can u pm me and tell me how to do it? i would appreciate it alot!!
Old Aug 22, 2006 | 08:25 PM
systalis's Avatar
Car: 92 RS
Engine: Built 355
Try this!
Standard Abrasives - DIY Cylinder Head Porting Guide
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
wanext
Oct 6, 2015 12:18 AM
Damon
Sep 26, 2015 04:29 PM
