engine casting number
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
just want to verify, can anyone tell me what year/model this engine came from and if it is a hydraulic roller block as opposed to flat tappet? casting number is; 14093338
I looked it up on MorTec but couldn't find a match. Thanks.
Re-check the number. Most likely, it's a 638.
If it's a 638, it's a 350; 86 - 95.
The casting # won't tell you if it's a roller or not, because that's a machining process that may or may not have been applied after the casting process. Truck and Caprice (TBI) blocks in most years got that block but were not equipped with roller cams; some other motors such as the L98 were.
Same for the next question, which will be, is it a 4-bolt main. Some blocks were equipped with 4-bolt main caps (trucks, maybe Covettes) but ones in cars generally were not.
your correct, it was a typo. according to mortec only corvettes got the 4-bolt main.
this engine in particular was pulled from an '89 firebird which had the L98 option and TPI... what are the chances this will be a roller block, and not a flat tappet?
Also if it is a flat tappet, can it easily be converted to roller by changing the lifters, or is machining nessessary?
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
you need a kit to convert it to roller if its not, but its probably roller already, hard to say for sure thouh without looking
you have to drill and tap bolt holes in the front of the block to bolt the cam retainer to
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
if this was the stock motor in that firebird, and I think there's a good chance it is, then it's a roller block, with roller lifters, and roller cam. (assuming you're buying all those goodies with the block).
1992 Trans Am
May 10, 2023 07:19 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
