EGR Valve testing
Old Aug 22, 2006 | 03:16 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
EGR Valve testing
All questions of "WHY", or "Just block it off" aside -- Texas
Dept. of Motor Vehicles makes the definitive requirement...
Does anyone know how to test the TBI EGR valve? I tried a
bench test vacuum application, with no results. The local
O'Reilly counterman (who has been right more often than not)
says that test doesn't work for these units -- even new ones
won't respond that way. And at $50+ per copy, its a little to
expensive to just replace.
thanks
ken koester
Old Aug 22, 2006 | 04:50 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
the EGR valve comes in 3 flavors, positive back pressure " P ", it needs some back pressure in the exhaust to work. negative back pressure " N ", it need to see a bit of vacuum in the exhaust to work. and one that doesn't care what the exhaust does. normally the different valves can be identified by either a " N " or a " P " on the end of the part number, the one that doesn't care won't have either a P or an N on it.
before you try this, you need to check to see if the EGR ports are open. with the motor at idle simply reach under the valve & lift up on the diaphragm, if there is little or no change in the motor your ports are clogged up & will need to be cleaned. a quick on car test i use to check the EGR valve is with the trans in park & with the motor at idle is to put direct vacuum to the valve & see if it opens, then do it again with the motor up around 2500 RPM. if the valve opens at idle & the EGR ports are clean, the motor will run very ruff or die, at 2500 you will hear a difference in the sound of the motor, normally it will drop by 100 RPM or more.
your O'Reilly counterman is kind of right, most people won't put their mouth on a dirty valve, but the positive & negative valves can be tested off the car, you must have a continuos good vacuum source hooked to it & either blow or suck on the port where the pintle is at.
bad EGR valves are common on all the TBI motors, i have replaced a ton of them. i also recommend to my customers they replace the EGR valve solenoid when ever i replace the valve.
Old Aug 27, 2006 | 07:44 PM
Jays92Camaro's Avatar
Car: 92 Camaro RS, 04 Dodge RAM
Engine: 305 TPI / Hemi 5.7L
Transmission: 5 speed / 4x4 auto
Denn - I have an 88 TPI setup and I'm having EGR issues...you mentioned the Positive, Negative and Doesn't Matter EGR valves...None of my manuals indicate which I should have...can you tell me which or is there a link. I'm sure I'm not the only one woundering. Thanks.
Old Aug 27, 2006 | 08:36 PM
305camaroRS's Avatar
Car: 89 Camaro RS, more
Engine: 305 TBI
Axle/Gears: 3.08
Thanks for all the info my car's SES light just went on i flashed it, and a 32 came up, havent looked at the EGR yet but all the extra info going in will help
Old Aug 27, 2006 | 08:56 PM
Vader's Avatar
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Out-Cast
Sep 3, 2015 09:05 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
