CVR Starter issues, need help!!
Old Aug 24, 2006 | 09:32 AM
1gta2c's Avatar
I have a brand new CVR mini starter and it will only start once after I tap it with a rubber hammer. I hace taken the plunger out and made sure the contacts are fine and all looks good. Is there any thing I am missing? Gear retracts after the the motor starts so thats not sticking. I don't know what else to do besides get a new starter!
Old Aug 24, 2006 | 12:00 PM
Damon's Avatar
I'd say you're on the right path with the new starter idea. The solenoid/bendix isn't doing it's thing when you apply juice to the "start" terminal.
Only other thing I could suggest before you blame the starter is to apply 12V to that "start" terminal via a known-good source (wire straight from the battery). If your ignition swtich and related wiring isn's supplying adequate juice to the "start" terminal the solenoid/bendix won't engage and, obviously, it'll never activate the electric motor to turn the engine over.
The solenoid/bendix must fully engage the starter's spur gear onto the ring gear of the flywheel/flexplate before voltage is sent down to the electric motor to spin the engine over. One must happen before the other.
Old Aug 24, 2006 | 12:57 PM
1gta2c's Avatar
Thanks for the reply, could this be a bad ground?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
TBRays98
Sep 6, 2015 05:05 PM
greenyone
Sep 2, 2015 03:39 PM
