Ping/Knock - How to tell?
Old Aug 28, 2006 | 09:35 AM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
Hey guys, nothing is wrong with my car... but I have always wondered what is this "knock" and "ping" sound that some people talk about. does anyone have a video/sound clip of this, and how to listen for it?
also another question:
how do i check for all of my cylinders hitting, and everything working fine on the engine? should i have a shop check it out? and, how much would they normally charge? 1 hour, 2 hours? etc.
Old Aug 28, 2006 | 09:38 AM
zeppelin5000's Avatar
Car: 1991 GTA Trans Am
Engine: 355 TPI
Transmission: 700R-4
It probably wouldn't be prominent enough to record, but it basically sounds like a rapid clicking from under the hood. That's the best I could describe it.....
Old Aug 28, 2006 | 10:52 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
Oh yes, it can be recorded if it's bad enough! It'll scare the **** out of you the first time you hear it, rattles like ****! Sounds like a handful of nuts loose in the engine.. You'll not be wanting to expose the engine to much more than a few seconds of that kind of torture.. It can come on gradually or more abruptly as you increase the load on the engine.
Old Aug 28, 2006 | 03:18 PM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
thanks also, can anyone answer my second question? I do have a v6, but it shouldn't be this slow... my grandma's van can out run my car it's also got a v6 (3.1), but i have to do about 1500-2000 rpm more than her to match her speed. it's retarded. anyways, let me know.
Old Aug 28, 2006 | 06:10 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Re: the second question. Read the plugs. I think there have been a few good wite ups on here over the years. If you are worried about the cylinders, do a compression or a leakdown test. Same there with regard to write ups. hth.
snowmad
Nov 28, 2010 09:33 AM
EagleMark
Jul 23, 2008 10:22 AM
albertschmitz
Aug 29, 2004 05:15 PM
HenryC
Aug 20, 2002 07:44 PM
age
Pacific Northwest Region
Feb 8, 2002 11:49 AM
