search engine light
Old Aug 28, 2006 | 04:42 PM
cowboys1's Avatar
search engine light
i just had a new fuel pump put in my 1988 camaro. the guy also run some injector cleaner through the injectors. now engine light is on. he says the injector fluid will burn off and it will be alright. is this true? or should i change my o2 senor? or what is going on? thks
Old Aug 28, 2006 | 04:49 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Do you know how to pull a trouble code? Check the codes and post it here. Don't buy any new parts 'till you know what the codes are.
Old Aug 28, 2006 | 08:57 PM
cowboys1's Avatar
i went to autozone and the guy said he could only use the code device on 95 and up. sorry, i don't know how check the codes.
Old Aug 29, 2006 | 12:20 AM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Heres how you do it. Look under your dashpad..near the pedals on the drivers side. You will see a female type plug inlet with 12 terminals inside of it. It is called the ALDL terminal. This is the ALDL in the person's hand:
Now, take note of the two connectors in the upper right corner on the top row. These are terminals A and B. What you need to do is...make sure the car is off. Take a paper clip and bend it into a "U" shape. Insert one end of the clip into Terminal A and one end into Terminal B. You have now jumped the ALDL. Now, keeping that there, turn your ignition on...DO NOT START THE CAR...just get it to that point where you turn the key and you get to the last click before starting the car...you know so that you can access your accessories but the car is not on. Now, take note of the "Check engine" light. It will blink a certain series of times...stop...then blink a second series...and then restart over again.
So for example, if it blinks 1 time...stops...blinks 2 times, then you have a code 12...see? You will ALWAYS get a 12 when you jump the ALDL, it is normal...it is just telling you that the ALDL is jumped.
Your code 12 will flash 3 times...after that, if there is another code (or two..three..four, lol) then it will happen AFTER the code 12 flashes 3 times...and THAT code will flash 3 times as well.
SO, if after the code 12 flashes, you get 4 flashes, a pause, then 6 flashes, then you have a code 46, which means you tripped the VATS (vehicle anti theft system)....but wait, dont stop watching until your code 12 comes up again. You could have more than one code, and they will appear in succession.
So each code is assigned to a different problem. Once you find out what your codes are, post them here, or search. It seems like a long winded process, but it is not, I was just being very clear here.
Good luck to you sir.
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
