LO3 auto chirps 2nd?
Old Sep 1, 2006 | 12:58 PM
streetassasin's Avatar
Car: 2001 SS
Engine: bolt on LS1
Car details: lo3, 700r4, 2.73 posi, catback only, 215/65r/15 tires
I was on my way home from school today and I thought t would be fun to run the car full throttle through 1st and 2nd. On the 1-2 shift the car ran strong and shifted right at 5500 rpm and it actually chirped the rear tires . It suprised me so much I didnt even go through second I just busted out laughing. I was wondering if any one else has done this?
Old Sep 1, 2006 | 02:22 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
I've been trying. But no luck so far.
Of course I have wider wheels, stock gears, and a leaking transmission. So that may have something to do with it...
Old Sep 1, 2006 | 03:20 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
My 91 LO3 does it almost all the time , Check out my VB garage for mods. I'm running 255/50/16 tires. I can't wait to see what happens when I install the new 700R4 in it (B&M shift kit, vette servo, modified boost valve, and a V6 S10 converter)
Old Sep 1, 2006 | 03:42 PM
krisb410's Avatar
Double post, Whoops
Old Sep 1, 2006 | 06:33 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
The 700R4 in my 84 MSE will put the back end of the car into the next lane when it goes into 2nd at WOT, and every now and again hear a little chirp when going into 3rd. Running 3.73's w/ 245/50-16's
Old Sep 1, 2006 | 06:36 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
My stock 170k mile LG4 camaro would chirp second every time. Only mods were an 80 series muffler and a $500 rebuilt transmission with a couple washers in a strategic spot that's why
did a hell of a burnout too.
Old Sep 2, 2006 | 01:04 AM
White93z34's Avatar
Car: 1987 Camaro IROC-Z
Engine: LB9
my LG4/700R4 used to do that before i put the 16" IROCs on it, dosen't do that anymore
Old Sep 2, 2006 | 01:18 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Mine does it too. About 3 min. after I start it before the engine and tranny get's warm. The weather has just cooled off after 90+ * weather all summer and the road surface is cooler too. The guy with 3:73's ain't got nothing to brag about, it ought to do it every time with those gears. Try it with 2:73's! A cheap shift improver kit will do it every time. After everything warms up about 15 or 20 min. it probably won't do it stock though. 5500 rpm? did you shift manual? If not, someone has thrown a reprogram kit in it before you got it. As far as the chirp, it was probably the right rear only, not TIRES! It's amazing how many reply to a post that aren't STOCK !
Old Sep 2, 2006 | 11:34 AM
krisb410's Avatar
I didn't see the part in the original post where it was for STOCK ONLY cars.
Oh and on my car it is always the left tire that chirps.
Old Sep 2, 2006 | 02:10 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
My right front does too.
Old Sep 2, 2006 | 04:37 PM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Transmission: 700R4,700R4
Axle/Gears: LSD,LSD
wellll my L03 did it when the fuel pump was goin out...had it to the floor tryin to clean it out a bit and i guess havin it to the floor, it made the tranny think i actually had "full" power to it, so there for it shifted hard...but otherwise..it aint happenin! haha
Old Sep 2, 2006 | 04:43 PM
Casey Butt's Avatar
Car: 1988 IROC-Z TBI
Engine: L04.3 = 305-310-336
Transmission: TH-700R4
Axle/Gears: 10-bolt, 3.42 posi
When I installed a TransGo Performance shift kit, polyurethane transmission mount, aluminum driveshaft and posi rear with 3.42 gears the car would chirp from 1-2 easily, 2-3 occasionally, and even 3-4 sometimes (car on a slight upgrade). Except for an open element air filter, CFM-Tech TBI and bigger injectors the L03 and exhaust was stock at that time (except for a gutted cat). I also removed the smog gear and played with the PROM tune a little. I'm assuming that those mods couldn't have made that much of a difference on an otherwise stock engine.
I was surprised at how much performance was to be found relatively easily in the drivetrain without doing much to the engine. After that I got more serious about transmission, rear-end and suspension mods.
Old Sep 2, 2006 | 09:58 PM
Car: 2001 SS
Engine: bolt on LS1
I let it shift on its own, since the tachs are so far off on these cars is was prolly around 5000rpm. So my posi car will only chirp one tire
Old Sep 2, 2006 | 11:33 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
I've had my honda spin the tires through all 5 gears before. doesn't mean I'm going any faster though
my 74 maverick with the straight six could sit there and let out one great smoke show as well in first gear but man it's kinda cheating also when you have studded snow tires on though.
Linson
Oct 24, 2025 02:00 PM
sp8ty
South East Region
Sep 24, 2018 03:55 PM
Lbibb
May 5, 2016 12:00 AM
Linson
Oct 1, 2015 09:50 PM
mfp189
Sep 27, 2015 09:25 AM
