Let's talk about seized engines!
Old Sep 3, 2006 | 08:43 PM
Epro's Avatar
Car: 95 Camaro Z28
Transmission: 4L60E w/ shift kit
Axle/Gears: 3.23s
If an engine makes a clicking sound when you try to start it, that means it's seized?
How do you unseize an engine? What're some tests you can do? My friend is over his head right now with a Firebird, which so happens to be the car I walked away from over a year ago!
Old Sep 3, 2006 | 08:48 PM
firstfirebird's Avatar
The easiest way to see if the engine is siezed is to get under the car and try to turn the fly wheel with a large screwdriver or small pry bar. The clicking could be a dead battery or faulty starter/selenoid. Don't fret yet!
Old Sep 3, 2006 | 08:49 PM
saliger64504's Avatar
Car: 1984 firebird trans am
Engine: 383 stroker
Transmission: th350
Axle/Gears: 10 bolt posi with 373 ring and pini
that clicking sound your hearing is your starter eather a bad cealanoide or the starter is locking up haft a friend try turning it over and hit the starter with a hammer if it frees it up its the starter going out if not have the starter looked at
Old Sep 3, 2006 | 11:59 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
I just had an engine clicking after replacing the starter and it turned out being a dead battery. The damn thing wont even take a charge anymore. Sometimes its something overly simple.
Old Sep 4, 2006 | 01:06 PM
ProjectIrocZ28's Avatar
Car: 88 Monte Carlo
Axle/Gears: Really Tall ones. Probably 2.73's
No. it means your battery is dead. a siezed engine would have one loud "clack" of the starter and then no movement from the engine at all.
Old Sep 4, 2006 | 02:44 PM
redlsone's Avatar
Ok I ran my car one day and it ome but overheated. I made it home but the overflow tank was going crazy. I started it the next day and things seemed fine. When the car sprung a hole in the radiator and my car overheated again and died.I had to push it in a parking lot. After I fixed the radiator the car still ran but was rough. Everything seemed fine except for an idle like a radical cam. Doesnt really matter because Im pulling it and putting in a 385ci
this week.Just kinda curious what could have gone wrong?
Old Sep 4, 2006 | 05:22 PM
shaggy56's Avatar
Car: 71 Nova
The solenoid will take less energy to energize so you will still get the click of the solenoid. If the appropriate power isnt goint to the starter motor then you will only hear the solenoid engaging. Sometimes the battery cable will have a bad contact with the starter but still able to energize the solenoid. This also happens with a bad solenoid.
Old Sep 4, 2006 | 05:43 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Yeah youre jumping to the wrong conclusion.... Try to turn it like they said by the flywheel, or by the balancer center-bolt...if the motor won't turn over that way, then you have issues.
redlsone....as far as you go, overheating it those couple times....I imagine it could have hurt a cylinder or two, causing your erratic idle.... Do a compression and leakdown test on the motor if you wanna know for sure, or if it's that bad, you should have one or two plugs that arent combusting properly like the rest.
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
Reddeath210
Oct 6, 2015 08:20 AM
dutch930
Sep 11, 2015 06:58 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
