Anyone here have engine modeling software?
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Wasn't quite sure where to put this, I figured that this was kind of a generic question, so maybe it fits in this forum...
I'd just like to find out if anyone here has engine simulation software that they'd be willing to use to help me work out the last little details of my combination. I already have a "pretty good, but still somewhat rough"
idea of the cam I'm expecting to use, but would really like to have something more than a "gut feeling" of how it'll behave before laying down the cash...
I already have the heads & intake I'll be using, so that's a known quantity. It would be great if someone had the DynoSim software, but even something more basic would be helpful. If you've got something like that, & wouldn't mind working with me a bit, I'd sure appreciate hearing from you...
Thanks guys.
idea of the cam I'm expecting to use, but would really like to have something more than a "gut feeling" of how it'll behave before laying down the cash... I already have the heads & intake I'll be using, so that's a known quantity. It would be great if someone had the DynoSim software, but even something more basic would be helpful. If you've got something like that, & wouldn't mind working with me a bit, I'd sure appreciate hearing from you...
Thanks guys.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The simulation software is only as good as the data inputed. Knowing things like head flow numbers greatly increases the accuracy of the output.
The best thing about simulation software is playing "what if". What if I changed to this cam, how much better would it be. What if I changed from a 600 cfm carb to an 850 etc.
Things simulation software can't predict is stuff like ignition timing, jetting, spark plug gaps etc. Those little variables can make a big impact on the final results. The simulation software is assuming all those small variables are perfect. If you build an engine recommended by software, a dyno tune should be very close to the predicted results.
Yeah, I work w/ computers all day, so I know that the better the data, the better the results.
My heads are AFR 195s, so I've got that data, I have a pretty good idea of all of the specs I'll want for my cam, I'm just hoping to throw a couple of variables in there to see if they make any difference, & if so, how much.
Tao, I truly appreciate this, I'll send you a PM in a couple minutes...
My heads are AFR 195s, so I've got that data, I have a pretty good idea of all of the specs I'll want for my cam, I'm just hoping to throw a couple of variables in there to see if they make any difference, & if so, how much.Tao, I truly appreciate this, I'll send you a PM in a couple minutes...
Linson
Aug 21, 2015 02:12 PM
