my engine makes a knocking noise,
Old Sep 10, 2006 | 02:05 AM
outlawracer's Avatar
Car: 82 camaro berlinetta/87 sport coupe
Engine: 87 LG4 305
Transmission: world 5speed
OK guys here's whats going on. My 305 LG4 is making a light knocking noise. its coming from the passenger side of the motor in the back around the 6th and 8th piston. when the car is running and I'm standing in front of the car you can barley hear it, but when you stand on the passenger side of the car near the door you can berley hear it. its almost sounds like its coming for the exhaust pipe or something. i dont know. what could it be
Old Sep 10, 2006 | 02:43 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Is this knock a 'clank' or a 'tick' sound? What does it sound like?
Old Sep 10, 2006 | 02:46 AM
Engine: 87 LG4 305
kinda like a hard ticking sounds
Old Sep 10, 2006 | 02:14 PM
Engine: 87 LG4 305
can anyone help, as i said, its kinda a hard ticking sounds. it kinda go's away when you bring the idel up around 2000 or abouv
Old Sep 10, 2006 | 04:55 PM
XSVortex's Avatar
sounds like it might be an exhaust leak... check to make sure the manifold bolts are tight.
Old Sep 10, 2006 | 04:59 PM
Air_Adam's Avatar
Yup, sounds like an exhaust leak to me too.. check the exhaust manifolds for loose bolts, and meaybe change the manifold gaskets.
Old Sep 10, 2006 | 05:47 PM
Engine: 87 LG4 305
i really hope you all are right, ive been morred about that knocking sounds for a good minute. i need to install some hearders so i jues now whould be a good time to take the old crap off. thanks guys big time
Old Sep 11, 2006 | 09:10 PM
91rsv6's Avatar
Car: 87 IROC Z
Engine: 5.0 TPI
my Iroc is knocking (rod) and when revved to 2000 or so it sounds horrible only when its warm and the oil is thinned out. But at idle its hardly noticible but know its time for the 350 build.
Old Sep 13, 2006 | 09:08 AM
Engine: 87 LG4 305
is it knocking or ticking?
theshackle
Sep 17, 2020 08:26 AM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
BlackBoulder
Aug 11, 2015 11:15 PM
