Iroc distributor fit on a 90 vette?
Old Sep 10, 2006 | 03:12 PM
PimpWillis's Avatar
Car: 88 Iroc
Engine: LB9
Transmission: WC T-5
I've been building a engine for my Iroc for a while now, and I just got to the point where the distributor is going in. The block is a 4 bolt out of a 90 vette and I can't seem to get it to sit flush with the top on the intake manifold. It sits about a quarter inch above it and I was just wondering if I need a new bottom gear for it or a new dist all together. I have the non HEI dist from a LB9...Any help would be greatly appreciated.
Brandon
Old Sep 10, 2006 | 03:14 PM
It's not sitting down onto the oil pump drive shaft properly. Get that lined up, and it will work fine.
Old Sep 10, 2006 | 03:19 PM
PimpWillis's Avatar
Car: 88 Iroc
Engine: LB9
Thanks, right after I posted this I thought about the pump shaft and bingo went right in after a couple turns
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
mustangman65_79
Aug 11, 2015 03:17 PM
