91 FireBird 3.1 coolent problem.
Old Sep 15, 2006 | 01:11 AM
m390's Avatar
Car: 91 Firebird
Engine: 3.1 V6
I am new here im stumpped really there is coolent leaking out under my driver side head it POURS out it even comes out with the car NOT running, when i have the car off i pour in water and then you hear it all come right back out. any ideas thanks.
Old Sep 15, 2006 | 11:20 AM
Damon's Avatar
Something is horribly wrong. Make sure you track back EXACTLY where it is coming from. If it is truly coming out between the head and block- she's toast. At least a head gasket, maybe more. This kind of gushing doesn't sound like a head gasket, though- they usually weep, seep and leak dribbles- not gush. I'm thinking more like something that screws into the water jacket unscrewed itself or snapped off, causing a MASSIVE leak.
Old Sep 16, 2006 | 02:44 PM
camarodrew's Avatar
Car: 91 rs
Axle/Gears: 4.10
could be a bad crack in the head or head gaket but like m390 said a head gasket doesnt normally gush
Old Sep 17, 2006 | 02:04 AM
m390's Avatar
Car: 91 Firebird
Engine: 3.1 V6
i found the problem there is a freeze pulg about 1 3/8 of a inch there to and the plug is gone lol but getting one back in is not going to be easy
Old Sep 17, 2006 | 02:21 AM
m390's Avatar
Car: 91 Firebird
Engine: 3.1 V6
new problem now i hear this is common tho but i have the pasenger side exhast gasget is leaking i hear it sounds like crap when you stomop on the gas , but im going to let the garage fix the plug so it will be out monday
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
db057
Sep 4, 2015 07:57 AM
justin57
Aug 20, 2015 07:05 PM
the_nikfive
Aug 11, 2015 02:46 AM
guy76767
Aug 6, 2015 05:58 PM
