Help, low oil pressure
I've noticed my oil pressure has gradually dropped. When the car is cold and idling the pressure on the gauge is about 1/3 from the bottom. When it warms up and idling it shows no pressure. When I accelerate when its warm it goes up to about 1/3 on the gauge. I checked my oil level and it full. What could be the problem? I did go to a shop they checked it and said it was fine its probably just the gauge. Is this probably it or is it something else?
Thanks.
Thanks. TGO Supporter
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
I would say that if your guage is running that low and even at 0 sometimes and the engine hasn't locked up yet, it's probably the guage or sending unit. I would replace the sending unit first. I had the same problem on my Beretta GTZ and replaced the sending unit and it fixed the problem. Should be fairly cheap replacement part.
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Oil Pressure
Had a problem with my 305, dropped to 0 psi and bought a mech. gauge and it showed 40 psi. Old electric gauges wear out and lie!
mechanical is best imho but i run both in my car 1 at dist. and elic. at the oil filter... they hardly ever agree with each other ...at start up the elic. will show 45psi and the mech. one will show 60psi...........tao
Car: 91 Firebird
Engine: 3.1 V6
i have never seen my gauge get above 40psi i think the gauge or sending until is bad on mine but again when im at a red light my car idles at like 500rpm dunno why bit it does and my oil pressure gauge read 0psi when im idle
Car: 88 formula WS6
Engine: 305 Lo3
Yup, my chevy truck (75) has a direct mech. gauge that is fed from the port beside the dist. and reads 60 psi. It's a factory mech. gauge that is 30 yrs. old. I installed an after mkt. gauge from the front port behind the water pump and it reads 40 psi at 3000 rpm. I figure that the fact. gauge is worn and reading high OR, my bearings are really worn and I'm losing pressure between the pump and the front oil passage. Only way to find out is install another after mkt. gauge from the port where the fac. gauge is hooked to. Mech. gauges over a long period of time loose tension in the spring that governs the needle reading and show a higher psi than what it actually is. Electrical sending units for some reason, tend to read lower.
ambainb
Apr 25, 2016 09:21 PM
