Intermittent Ticking
Old Sep 18, 2006 | 07:11 PM
86_z28's Avatar
Anyone out there ever dealt with a carbed 305 with an intermittant ticking sound. It sometimes will start with the motor under load and sometimes just sitting there idleing, no ryme or reason to it at all. It sound like its coming from the lower half of the motor or where the tranny meets the motor. Its not an exhuast leak (I was hoping thats all it was). The motor runs very strong, although it has 122k on it. Any ideas?
Thanks!!
Old Sep 18, 2006 | 07:25 PM
kjvail1204's Avatar
Flex plate, at least that is what mine was, and you want to get it fixed ASAP cause it can do some real damage if it comes off, IE, come up through your floor
Old Sep 19, 2006 | 06:14 PM
86_z28's Avatar
Thanks!! I will check that out. Based on your experience, will I be able to tell if it is cracked or damaged by pulling just the bellhousing? Or will I need to drop the tranny to do a good inspection?
Old Sep 19, 2006 | 08:43 PM
kjvail1204's Avatar
Drop the tranny, again this is an Automatic correct? You'll have to drop the TC off of it and check both the bolt pattern or the larger holes.
Old Sep 25, 2006 | 05:21 PM
kjvail1204's Avatar
update
Old Sep 25, 2006 | 11:36 PM
NoTransistors's Avatar
Car: '83 Firebird S/E
Engine: The Chevy 305. with carburator
Transmission: 700R-4
Speaking of intermittent noise...
My car has had one for seven years. Comes and goes just like our buddy's noise, but NEVER [yet], at idle. It disappeared all last winter. Not a tick, but a noise more like exhaust leak, or the cooling fan gently hitting the shroud. A few weeks after cleaning up my exhaust, the noise became more or less constant. I say this because the exhaust near the engine is now more or less free of soot, as we are now running lean. Soot can fill holes in the exhaust. I have no clue. When I pulled the twin down-pipe down two years ago, I found little evidence to support my theory that the shaft on the heat-riser is leaking. I am at a loss, and will need a looney bin soon, if this is not resolved.
When listening from inside, the noise appears to eminate from the right footwell, but sticking my head out the window, the noise is very much quieter, and hard to pinpoint.
Seth
Old Oct 19, 2006 | 08:19 AM
86_z28's Avatar
Sorry for the delayed response, I have been very very busy lately. I checked the flexplate/flywheel and all was fine. I decided to then start tearing into the motor and come to find out it was a sloppy timing chain slapping against the timing cover. Replaced the cam gear, crank gear and timing chain, at the same time replaced the fuel pump and greased the pump pushrod (had to pull fuel pump to remove motor mount bolts and the arm looked kind of oddly worn). Put everything back together and the motor runs nice and quiet and much smoother too.
Chris
Old Oct 19, 2006 | 08:40 AM
sully91rs's Avatar
Car: 91 RS, 95 Z28
Engine: 305 tbi, 350 lt1
Transmission: 4l60, 4l60e
Axle/Gears: monsterous 2.73s in both
Wow, a loose timing chain caused the ticking?
I think I may have that problem. There is a ticking at idle, but after I give some gas it goes away. I was thinkin loose rockers but shouldn't that get louder as the engine speed increases?
Good job on pinpointing the problem!
Old Oct 19, 2006 | 02:20 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
I have this problem as well. It goes away with throttle but doesn't really appear to speed up with it applied.just kind of fades out.
Old Oct 19, 2006 | 07:31 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
I have a similar noise. I think it is related to the AIR System. I currently am suspecting the diverter valve.
Old Oct 20, 2006 | 11:16 AM
sully91rs's Avatar
Car: 91 RS, 95 Z28
I have my AIR removed except for the air pump is still on the engine and runs on the belt. That DEFINETELY adds a ticking sort of sound, but it isn't the same as the sound I'm hearing at idle.
Plus, I had the sound before I removed the AIR system.
I'm not telling you it isn't your AIR, I just wanted to add that if the AIR system is leaking it will cause a ticking sort of sound, but it has a different sound than what I am hearing at idle.
Old Oct 20, 2006 | 01:29 PM
mbrownone's Avatar
Car: 3rd Gen Trans Am
man, i wish i knew what was causing the clicking and ticking noise in my car too. i just finished doing an intake change to an edelbrock and i hear a loud clicking from the interior. when i raise the hood i cant hear it out there, just inside the car.....really strange, but i parked it in my garage until i find out what it is.
Old Oct 20, 2006 | 07:54 PM
86_z28's Avatar
That sounds more like an exhaust leak. Usually you can hear the smaller pinhole leaks better inside the car because when you try and listen under the hood the other normal engine noise drowns it out. Try this as a test, put the car in drive and brake tourque it, if it is exhaust the noise should become more pronounced because that puts the engine under load. Let me know how it turns out.
Old Oct 31, 2006 | 02:01 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Mine intermittant-ticking turned out to be the mechanical fuel pump.
Old Oct 31, 2006 | 11:14 PM
I have been too busy to even do the p.s. pump. Came from AGR last week. Need to install before winter. The present unit runs dry in seconds.
Anyway, 86_Z28 has just said something that makes sense. After the pump, I will give it a try.
P.S., the fuel pump and pushrod are new. AIR system is temporarily w/o the belt, to eliminate this as the noise. At one time or other, every darn thing on the engine, except the alternator and water pump, has been temporarily removed in an effort to find the ******** noise.
THANKS,
Seth
Old Nov 2, 2006 | 02:15 PM
mdurbala's Avatar
Car: 91 Camaro RS
Engine: 305 tbi
sounds like everyones is doing it, i had someone tell me it might be the bearing in the waterpump but its not that old... timing chain does seem to make sense, that pretty hard to do yourself?
david068513
LSX and LTX Parts
Nov 15, 2015 11:37 PM
Reid Fleming
Oct 10, 2015 09:56 PM
meeklay812
Oct 1, 2015 03:46 PM
david068513
Sep 13, 2015 11:24 AM
david068513
South East Region
