What plugs and wires after header install?
Old Sep 19, 2006 | 06:01 PM
bigjay89gta's Avatar
Car: 89 GTA
Well after installing my hooker 2055's I have burnt up 2 wires and was wondering what plug wires you guys recommend?
Do they have some that will fight right? The stock wires on two I had to flip them around because the 180 boots wouldn't work with the headers. I am guess I need all 90 degree boots.
Does going with a 8.8 or 8.5 mm wires help?
Should I just get rid or my bosch platinums and go with AC Delco or maybe NGK plugs?
About a 1.5 years ago I do cap rotor and wires and left my bosch platinum 4s in? Should I replace can and rotor? I went with the brass top cap and rotor. not accell or msd.
Jason
Old Sep 19, 2006 | 06:30 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
I really like the taylor wires there 8mm spiral and 50 ish bucks
Not a bad deal and they look good just my
Old Sep 19, 2006 | 09:41 PM
back in black's Avatar
Car: 86 Iroc
Engine: 305 tpi lightly modified
Axle/Gears: 4 10's
After putting Heddman's on I bought 8.5mm MSD all 90's and made them fit quite nicley under the headers and up the back.I prefer the hidden look.If you can affored probably best to get a new cap/rotar and plugs.Then you know it's all fresh.If your fairly stock the stock cap is plenty.
Old Sep 20, 2006 | 07:22 PM
Car: 89 GTA
Thanks for the help guys.
But I just blew all my money replacing my ignition lock cyclinder since it locked up. But know I am a professional at doing it I have do it 3 times today. LMAO everytime I get in a hurry I forget something so I had to take it apart and put it back in LOL. Man that sucked. But hey I kept vats working and have a new set of keys and stopped the whopple in my steering column so it was worth it.
Old Sep 21, 2006 | 11:36 AM
Damon's Avatar
If you're using stock cast iron heads then you can get a set of very affordable Autolite 24s in there- they're a fair bit shorter than stock, but not quite as short as a set of Accell shortys. They are otherwise exact replacements for stock and help header clearance quite a bit with some sets of headers. Projected nose, designed for a ~.045" gap, 1 heat range colder than most "stock" application plugs. Perfect for use on a mild performance motor with an HEI or other electronic ignition system.
Yes, you need all 90* boots. I've used junkyard wires back when I had no money. Swipe a bunch of decent looking ones with the required boot angles off junkyard cars for nothing and try them out. Sometimes they are trashed, sometimes they work just fine. V8, V6, 4 cylinder- makes no difference- if it's got an HEI distributor the wires will swap.
I figure you're out of this for about $15.
Old Sep 21, 2006 | 11:42 AM
Car: 89 GTA
right how I had some old ones laying around from when I did it last time so I just put those in till next payday they seem to be working. yeah I will look into those autolites
jason
specialized
Jun 18, 2022 09:26 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Brcharrelson
Aug 26, 2015 07:47 PM
Exxon Limited
Aug 9, 2015 08:13 PM
92projectcamaro
Aug 6, 2015 01:20 PM
