bucking off idle some one help
Old Sep 25, 2006 | 10:18 PM
89305formula's Avatar
Car: 89 formula
Engine: 305tpi
Transmission: t-56
Axle/Gears: ford 9" 4.11s
i got an 89 305 with a 5 speed and its got a bad miss in the motor only when im driving and below 2k rpm if im crusing along at 1900rpm it will do it but i just give it alittle gas and it goes away i checked the tps and it was a t .54v with the blades clossed and it increased evenly to 4.01v at wot, i cleaned the throttle body put in new plugs cap rotor fuel filter and the maf sensor cause i had a code for it and every now and then i get a code 36 for maf sensor burn off relay but i havent replaced that cause its real intermintent
and it has new injectors in it so i basically dont know where to go from here so any suggestons would help thanks
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
IROCtometal
Sep 20, 2015 11:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
greenyone
Sep 8, 2015 08:41 PM
