Cam for tpi....
Old Oct 2, 2006 | 07:26 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Cam for tpi....
Need a cam to work well with a factory tpi setup and prom.. I'd prefer something more aggressive than stock.. I'm looking for something cheap like a summit grind.. Anyone have a suggestion or two?
Old Oct 2, 2006 | 10:53 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Yea, don't use a summit grind.
Factory TPI setup - I'm 90% sure that's a roller cam, so I don't think a summit grind would even work. (unless you're talking about your vette...)
Cheap? LT1 takout cam is your answer. It's a common upgrade for your application, and for good reason.
Old Oct 2, 2006 | 10:54 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Depends a lot on whether or not you're willing to tune the engine.
Old Oct 3, 2006 | 04:14 PM
89RsPower!'s Avatar
Factory TPI setup.. block is a 72 or so 350 2 piece rms w/flat a tappet cam. LT1 cam would be a roller cam AFAIK... Need a cheap flat tappet cam..
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
