2 quart oil filter????
Old Oct 3, 2006 | 12:15 PM
Firebat's Avatar
Wondering if i should put in a 2 quart oil filter on the LT1. The LT1 has the same filter as all sbc 350's.
Normal Filter:
http://www.knfilters.com/search/prod...x?Prod=HP-2002
Normal Filter with anti drainback valve:
http://www.knfilters.com/search/prod...x?Prod=HP-2003
1.5 Quart Filter with anti-drainback valve:
http://www.knfilters.com/search/prod...x?Prod=HP-3002
2 Quart Filter(not available through K&N with anti-drainback balve):
http://www.knfilters.com/search/prod...x?Prod=HP-6002
For the 2 quart, I would probably use a WIX because WIX probably has the valve. People are using the 1.5 quart filter with no problem. Just wondering if anyone has tried the 2 quart and if there would be an advantage to using the 2 quart.
Old Oct 3, 2006 | 12:20 PM
Sure; if you want the filter to be THE LOWEST POINT on the car. In other words, the first thing that scrapes and gets torn off.
Old Oct 3, 2006 | 12:36 PM
Firebat's Avatar
that bad, I'll have to bust out the tape measure.
Old Oct 3, 2006 | 12:50 PM
Firebat's Avatar
its pretty close to the lowest point. 8" from where the oil filter is screwed in: about where the bottom of the oil pan is at. This thing is 8.3" It would be about an inch higher than the y-pipe. I think the ypipe is my lowest point.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
89 formula TPI
Sep 7, 2015 11:06 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
