Does she look healthy?
Old Oct 3, 2006 | 03:19 PM
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
I just wanted to get all of your opinions before I went out and removed the other head...
Old Oct 3, 2006 | 03:35 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
looks pretty normal.
What are the plans?
Make sure to clean up the block deck well. I like either scotchbrite on an angle grinder, or a wire brush on a drill. Not sure if you can re-scuff up the cylinder walls with the pistons still in or not...
Old Oct 3, 2006 | 05:15 PM
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
Plans are to cam it..I took the heads off to get the springs installed since I cant and wont do it my self.. I might even ber getting vortecs instead..
O yeah
BTW
I got the other head off, not bad for a 15 year old, that wasnt out of school till 2:30.. i hope..
Old Oct 3, 2006 | 05:41 PM
Sonix's Avatar
Car: 1982 Trans-Am
Don't put vortecs on your 305, your compression will be too low.
ah, I see in your sig, the xe262 - good choice for the 305. Machine shop doing the springs for ya? good, good...
Got a dremel or die grinder? Might want to sand smooth the combustion chamber...
Looks good, just make sure to clean everything religiously. Like eat off it clean. That cloth in your lifter valley is a good idea.
Old Oct 3, 2006 | 06:31 PM
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
to low? I read an article about a 325 hp lg4 with vortecs and it said to high..
Im not really diggen the go, Im more into the turns and things but, their is no way im gonna have the car sitting for 4 months now not runing and it not getting faster or lighter..
edit
that might be rust in #3 i beleive its just on the ring..
Old Oct 3, 2006 | 07:03 PM
Sonix's Avatar
Car: 1982 Trans-Am
nope, too low. I'd have to see that article.
You have 58cc heads, and a stock .015" thk gasket.
Once you put on the .039" gasket, your CR drops a bit. Put on 64 cc heads and it drops again. That motor might have 9:1 CR, with those changes your down in the '8s. That's lame.
Old Oct 4, 2006 | 08:53 PM
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
Old Oct 4, 2006 | 08:54 PM
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
Old Oct 4, 2006 | 09:23 PM
Sonix's Avatar
Car: 1982 Trans-Am
good job cleaning.
You should be able to close your eyes, and run your pinky, or fingernail, along the deck surface, and not feel anything. No nicks, no bits of junk, etc.
What did you use to clean it?
86White_T/A305
Mar 6, 2016 01:48 PM
InfinityShade
Feb 21, 2016 01:29 PM
GTAman
Sep 21, 2015 09:57 AM
NiG
Sep 2, 2015 06:54 AM
ViciousZ
Nov 5, 2001 02:34 AM
