help with ignition module please
Old Oct 8, 2006 | 07:32 PM
liquidrider3214's Avatar
ok im not getting any spark from my 87 z28 and was told to replace the ignition module already replaced ignioin coil, and its not getting any spark from the coil( held wire 1/4 inch from chassi wile someone turned over motor and no spark) anyway the ignition module i cant seem to find i checked under the rotor and didnt see anything that looked liike the one advanced auto parts gave me. heres some pics
[/IMG]
Old Oct 8, 2006 | 07:49 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
That's not a stock distributor, so the module you have from the parts store won't work. Looks like a mallory unit; you'll probably have to get a part # off the dist. to get a correct module (if that truly is the problem). Good Luck!!
Old Oct 8, 2006 | 08:02 PM
ya its a mallory unilite. so the stock module wont work?
Old Oct 8, 2006 | 08:09 PM
Lo-tec's Avatar
square peg, round hole
edit...how did you check for spark?
Try sticking a screwdriver in the plug boot, and hold that less than a 1/4" from the frame, header, etc and see if it sparks when your buddy cranks it.
Old Oct 8, 2006 | 08:17 PM
that is exactly what i did sorry i forgot to do that, no spark at all, what else could be at fault?
Old Oct 8, 2006 | 08:33 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
If the dist is wired correctly your unilite ,odule is bad. I have never had too much luck with those things anyway. Best bet would be to go down to the local parts store and get a stock HEI dist. Otherwise if you want to fix what you got. Call Summit or Jegs and get a new module for the unilite. The module is the part in the first picture. They are pretty easy to replace.
Old Oct 8, 2006 | 09:07 PM
is the red part inside the distributor that is about half the size of the inside of the distributor that says mallory on it the module?
[/IMG]
Old Oct 8, 2006 | 11:07 PM
Comp788's Avatar
It sure is. I forget how to check it. You can call mallory and get directions for checking it. It has been years since I used one of those things. As I recall it has three wires on it. Red is to key on (Ign), green is to the coil and black is to ground.
Old Oct 9, 2006 | 04:39 PM
well what are the symtoms of a bad ignition module?
Old Oct 9, 2006 | 05:20 PM
Comp788's Avatar
Well the first question would be was the car running and then just died or did you change things and now it will not start?
Symptoms of a bad module would be no spark. In your case it should also have the power wire to the module getting power. It is also important to know for a fact that the coil is good. Make sure that the coil that your using works with a unilite. MSD make a few different coils and some only work with their stuff.
Old Oct 9, 2006 | 05:55 PM
yup didnt change anything car was running perfectly fine got in the battery was low i knew it was bad anyway and was on its last legs so i walked nextdoor and bought a new interstate battety put it in expecting it to start and nothing had to have my father push me home with his minivan, anyway i knwo the coil works with it because i replaced it with a brand new one same one as the old one, so how can i test the power wire?
Old Oct 9, 2006 | 06:16 PM
ok i just checked the power to the module dont have a meter so i stripped off about 1/4 inch from the red wire and touched it to metal while someone turned the motor over and got a blue spark so the module is getting power
Old Oct 10, 2006 | 02:57 PM
ok replaced ignition module started up right away thank you for all the help, but now its idling real low and sputters a whole lot when at low rpms until i get up around 2000 rpms then it starts going normal so im convinced its getting too much fuel if i give it alot of gas or not even fast just normal it pops and a puff of gas shoots out the top of the carb, how do i adjust the carb air fuel settings because im pretty sure one of them got messed with and now its getting too much gas. how many turns out from closed on an edelbrock carb is factory tuned?
Old Oct 10, 2006 | 04:57 PM
Comp788's Avatar
Glad that you got it running.
Setting of the carb is different on most cars. You just need to tune it for what works good for your car. Start from fully closed and open a turn and a half. That is a good place to start.
Old Oct 10, 2006 | 06:52 PM
thanks on both screws or just one? ill go try right now
Old Oct 11, 2006 | 12:55 PM
Comp788's Avatar
typically they should be adjusted the same.
Old Oct 11, 2006 | 03:49 PM
im sure its not the carb right now, i was thinking that i installed the distributor rotor wrong but i called mallory tech support and they told me that it only goes on one way and even the motor is turned with the cap off it wont affect it, he told me it is most likely my timing so i really dont want to pay the shop 80$ for setting the timeing seeing as how a timing light is only 40$ im going to buy one but how do i set it?
InfernalVortex
Apr 20, 2021 11:31 AM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
dusterbd
Sep 29, 2015 08:40 AM
tattmann
Sep 27, 2015 05:20 PM
