87 LG4 heads
Old Oct 9, 2006 | 09:26 PM
Fstbk272's Avatar
Car: 87 Firebird, 90 corvette, 05 F150
Engine: 5.0, 502, 5.4L
Transmission: AUto,Auto,Auto
87 LG4 heads
are the heads angle or straight plugged? Thanks - Roger
Old Oct 10, 2006 | 12:11 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Straight I think. Most factory heads are straight.
Old Oct 10, 2006 | 12:23 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
1987 LG4 heads would be 081 or 187 castings. BOTH are straight plug heads.
Old Oct 10, 2006 | 05:14 AM
Fstbk272's Avatar
Thanks. - Roger
Old Oct 24, 2006 | 08:51 PM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
are these heads any better than lo3 heads?
Old Oct 24, 2006 | 08:59 PM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
Yes
Old Oct 24, 2006 | 09:27 PM
johnnyboy's Avatar
can i take a set of these heads and have them bolt right onto my tbi setup on my lo3 without a problem?
Old Oct 24, 2006 | 09:39 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
MANY of the LG4s have 187 head castings, that is the SAME casting as the TBI 305.
Define "BETTER"
They do flow a little better on the intake side, but lose just as much on the exhaust.
You go from 175 CFM intake on the TBI heads to 195 CFM intake on the TPI heads. But you go from the 135 CFM exhaust to about 105 CFM on the TPIs.
You also lose the "FAST" burn capability which necessitates more timing advance for peak HP. More timing advance starts the air/fuel mixture burning sooner. That means the pressure from combustion is actually fighting the pistons still upward movement for about 6* farther with the TPI heads than the TBI heads. When the total window is about 50*, 6* is alot of the time and alot more negative work on the crankshaft. Going on 28* BTDC total advance for the TBI heads, 36* BTDC total advance for the TPI heads, and peak cylinder pressure about 15* ATDC.
The end result is you end up trading ALOT of low-mid range torque and take a terrible hit on gas mileage for a little more power over 4,500 rpm. (I took Dewey's PORTED 416s 4,200 rpm to rise to the level of the STOCK 187 TBI heads and start pulling ahead on his CAMMED 305).
Spend your time and money working on the Exhaust, Chip, and tiny camshaft(1.6:1 rockers at the minimum).
Old Oct 24, 2006 | 10:11 PM
327???'s Avatar
i did not know that, i thought they always had 416's.
Old Oct 24, 2006 | 10:20 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
NOPE, 1987 introduced the center-bolt valve cover heads, 081 and 187. I think I have seen more 1987-1988 LG4s with 187s than I have with 081s. Keep in mind that the LG4 was also used in 1988 in the Caprice and Monte Carlo.
Old Oct 24, 2006 | 10:30 PM
johnnyboy's Avatar
so are these 87 305 carb heads any better than my 89 305 tbi heads?
Old Oct 24, 2006 | 10:35 PM
Sonix's Avatar
Car: 1982 Trans-Am
Did you read Fast355's post at all?
They very well might be the same head casting. What # are they?
That's kinda a loaded question, everyone on these boards like the 416/081 castings, except Fast355, and about 3 other people on the TBI board.
The ramp in the intake limits flow at the upper RPM limit. The TBI heads are better for low RPM (there, i'll give ya that one..), and the heads without the ramp (416's, 081's, 601's etc etc) are better for higher RPM.
What do you have and what do you want?
Old Oct 24, 2006 | 10:36 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Stock for Stock, NO
Ported and Ported, DEPENDS on the application
What cam do you have?
Chip Burning?
Exhaust?
Intake setup?
Transmission setup?
Rear-end gearing?
What are you planning to use the car for? Daily Driver, Street-Strip, Drag, Road Race, Autocross?
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
92projectcamaro
Jan 18, 2016 08:00 AM
New2Chevy
Sep 28, 2015 12:35 AM
z28guy134
Sep 1, 2015 11:50 PM
