starting probs 350 tpi
Car: 1987 trans am
Engine: TPI 350
Axle/Gears: 342
tpi 350 engin light will not light but will crank a few thousands times then light and then start any ideas to what or why? please help havent drove in three years because of it and despareatly want to get her back on the roade again
Car: 82 Z-28
Engine: 383 TPI
One possibility is the fuel pump isn't coming on until you build up oil press. The fuel pump relay is supposed to run the fuel pump (for a few seconds) as soon as the key is turned to the "on" position. If the relay fails, there's a back-up way to power the pump; that's by using a oil press switch down by the oil filter.
If the relay fails, the eng will start after it's been cranked long enough to build up oil press.
Do you hear the fuel pump run for 3-5 seconds when key is turned to the run position?
Babybear82, It sounds like your timing chain might be going out. To check this remove the dizzy cap and turn the crank back and forth. The rotor cap should move everytime you turn the carnk. If this does not happen, the timing chain is loose and causing you to have to turn the car over a lot before starting.
theshackle
Mar 5, 2017 06:37 PM
Sanjay
Aug 12, 2015 03:41 PM
