oil on spark plugs
Old Oct 19, 2006 | 09:26 AM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
oil on spark plugs
I've put about 1500 miles on my 383 I built, and i decided to change the plugs because i was sure I'd fouled them pretty bad while tuning the carb and setting timign and what not. so i pull the first 3 plugs last night from the passenger side head, and lo and behold, 2 of the three plugs (2 and 6) have a fair amount of oil on the threads, and a little on the elctrodes too. wtf? are my rings FUBAR already? it's not knocking or making funny noises. it's really hard to turn over by hand at first (once it gets going, it's not as bad), the rings are NEW and I bored the cylinders .030...... the pistons are the right size....what do i do? what's the most likely things going on here?
Old Oct 19, 2006 | 11:00 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Probably just not fully seated yet.
Have you run it hard yet? Engine braking as well?
Old Oct 19, 2006 | 01:03 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
There are a lot of opinions on rings seating. Some people say they seat when you turn the motor over on the stand. Others say they will seat in 20 minutes of run time and some still say it takes a couple hundred miles to get them fully seated. One thing I firmly believe now is to run it hard to get everything broken in. Drive it like you stole it after first startup (and everything checks out).
Are you getting any smoke from your tailpipes (burning oil)?
Was the car running extremly rich to maybe wash the walls down?
The only way to be sure is to do a leak down test...time consuming but faster than a re-ring.
Old Oct 19, 2006 | 01:04 PM
Car: 1982 Trans Am
Engine: 383 chevy
now that the board is back up..... yes, I've gotten on it a coupd of times, and engine braked a couple tiems also. not much... maybe 3 or 4 times each. I'm not getting any smoke or anything. it was running a little rich, but not that bad. I corrected it pretty quick.
Old Oct 20, 2006 | 12:23 AM
AtomicTruck's Avatar
Car: Pro Stadium Tough Truck
Engine: Buick V6 272 cu in
Transmission: TH350
Axle/Gears: Broken most of the time
New motors are always tight to start with.
Are you absolutely sure the stuff on the plugs is oil? Could it be coolant? (is it greenish on the electrode) If so then you may have a bad head gasket. White smoke is coolant, blue smoke is oil and black smoke is fuel. Any smoke?
Old Oct 20, 2006 | 01:12 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Old Oct 20, 2006 | 06:48 AM
Car: 1982 Trans Am
Engine: 383 chevy
he's right. and all the gaskets have less than 6 months on them. it's brown, and smells like petroleum. i'm inclined to think the rings aren't seated or the valve seals/guides are bad.
Old Oct 20, 2006 | 09:02 PM
Transmission: TH350
No smoke.... If it were mine I wouldn't worry too much at this point. I'd just run it a little harder than normal for a few days. Don't go nuts on it but make it scream a little...
Check your plugs on a regular basis, maybe take a few notes to keep it all straight. 1500 isn't really enough miles to make any difinitive conclusions. But it is enough miles to know that you don't have any major problems.
Old Oct 20, 2006 | 09:53 PM
Car: 1982 Trans Am
Engine: 383 chevy
ok. I'll keep watching it. I'm still changing the plugs out (i work a lot and i have headers....) but I should have it done this weekend. I'll see what it does. love the avatar, atomic truck. do you know what the chain of command is?
Old Oct 20, 2006 | 10:43 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Oil on the spark plug threads is a sure indication that your valve covers gaskets are leaking.
Old Oct 21, 2006 | 03:13 PM
Transmission: TH350
Yes I do...
It is the chain that I beat you with until you figure out that I'm in charge!!!
I love that line in the show
Old Oct 21, 2006 | 03:22 PM
Car: 1982 Trans Am
Engine: 383 chevy
finished the spark plugs just now. I have to go to work, so I'll crank it tomorrow and see what happens. she needs a new coil anyway. "this is the finest weapon ever made. I swear it's more than a fair trade!"
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
LittleFranks
Sep 17, 2015 12:22 PM
