Are my pushrods interfering with my Heads???
Old Oct 23, 2006 | 10:12 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
When I pulled the motor apart I noticed some worn areas on my heads where the pushrods go through. Its the very first and last pushrods on heads head...the 4 corners.
Is this machined like this from the factory or is something wrong here?
I want to eliminate and possible noises on startup so this goes as smooth as possible. If this is a problem can I just grind to make the psuhrods not touch?
Old Oct 23, 2006 | 10:40 PM
EvilCartman's Avatar
Car: '82 Z28
Is there a wear pattern on the pushrod or head? Best as I can tell from the blurry picture, that's machined.
Old Oct 23, 2006 | 11:26 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
if it's wear going up and down then it'd be from the pushrod, those marks look concentric, ie, from a cutter.
zoom out though, I have no idea what that's of really.
I don't think it's a problem though.
definately don't grind the pushrods.
Old Oct 24, 2006 | 02:10 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
I was thinking it was machined too. There were some wear marks on some of the pushrods but I can't remember if it was on the same valves.
On both heads where the pushrods may be hitting one end is machined (or worn) as you see in the pic; kind of from the top to the bottom. The other end of the head the machined place is about half as long. This is the exact same for both heads.
Old Oct 24, 2006 | 10:22 AM
AtomicTruck's Avatar
Car: Pro Stadium Tough Truck
Engine: Buick V6 272 cu in
Transmission: TH350
Axle/Gears: Broken most of the time
It is quite possible to have pushrods rubbing on the head, especially if you have other than stock rockers or heavy duty rods. You can take a die grinder and an abrasive wheel and just take a little off the head. You might want to do this just to make sure.
However, it is very important to try to determine how thick the material is in this area (water jacket). You don't want to take off too much and it really shouldn't take a lot to fix this. I would NOT use a carbide, just use a rough abrasive wheel (the sandpaper looking ones). I might start with a stone wheel of the pushrods are worn pretty bad... but don't go nuts on it...
This is why I always keep the pushrods in order when I take an engine apart. Inspecting the pushrods is really the way to verify this type of problem.
Old Oct 24, 2006 | 11:30 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Pushrods are still in perfect order I just havn't checked them. I may clearance them a little eevn though both heads are perfectly matching (machined?).
I'm running Comp ProMags and Trickflow 5/16" pushrods 7.400" long...
Old Oct 24, 2006 | 08:56 PM
sixpackmtrspts's Avatar
what heads are they? i built a 383 a while back and i used dart pro 1 aluminum heads, i had to grind the area the pushrods go thru to get enough clearance for them. i probvably shoulda went with offset rockers and lifters
Old Oct 24, 2006 | 09:03 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
They are Trickflow 23 Degree heads. I did al little grinding even though I don't think they were hitting. Should defenitly be good now.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
92projectcamaro
Jan 18, 2016 08:00 AM
New2Chevy
Sep 28, 2015 12:35 AM
z28guy134
Sep 1, 2015 11:50 PM
