Would an L05 purchased in 2001 with 193 heads have roller or flat tappet lifters?
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
See title, I'd like to know what I've got under there without tearing it apart.
Car: 1983 G20 Chevy
Transmission: 4L60
You are going to have to atleast pull a valve cover. There were atleast 4 different L05s available from GM. 3 are still available to this day. If you pull a valve cover you should be able to peer down past the push rod and see what is there. It will have the link bar between the lifters if it is a roller. If it is without the link bar, it is not roller.
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Damn...I just had a cover off to get the head number and I put it back on. Guess it will have to wait, I dont feel like pulling the cover again.
I know of the 3 L05 engines. However I am also pretty sure that only one of the three came with 193 heads so I figured that would be the deciding clue.
Car: 1983 G20 Chevy
Transmission: 4L60
Here are the 4 and they were all 193 heads.
A 5th had 906 castings on it and was only used for the 1996 model year.
Caprice 9C1 with L98 roller cam had 193s
Light Duty truck engine had a hydraulic flat tappet cam and 193s
Heavy Duty truck engine had a hydraulic roller cam and 191/810 heads
Caprice/Fleetwood/Roadmaster/Custom Cruiser had the peanut roller and 193s.
ambainb
Apr 25, 2016 09:21 PM
Mickeyruder
Sep 2, 2015 02:45 PM
