1 problem left with formula
Old Oct 30, 2006 | 09:24 PM
jer87formula's Avatar
I rebuilt the front end today new everything.
Its like a new car now. Gezzz what a difference..no more wandering.
Still have the shifting problem. Let me explain it again.
When driving slow 25 to 30 mph the car shifts (1 normal) then (2nd hard) then (bogs 3rd)..
when driving 40 and over still shifts hard to 2nd and no bog in 3rd.
I was told there is a shift pack in it never heard of one for an automatic with overdrive.
and all of the above symptoms are in regular drive not over drive but does it in over drive also.
could this be a tourq converter problem?
If you have had the same experience please point me in the right direction.Because i know if i go to a tranny shop there gonna hit me hard .
Old Oct 30, 2006 | 09:27 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
tv cable adjusted properly?
Old Oct 30, 2006 | 10:15 PM
yes pushed it in full throtle out...still same
Old Oct 30, 2006 | 11:52 PM
Its strange no one else has had this problem.hmmmm
Old Oct 31, 2006 | 08:43 AM
Damon's Avatar
GM has some funny lockup torque converter programming in the chips of the early TPI cars. Like hitting 2nd and almost immediately locking up the converter a very low speeds causing "bogging", similar to what you describe. Not really bogging, but lugging the engine down rather low.
GM actually had the lockup converter programming changed for the early TPI cars for anybody who complained about it- a different chip, basically. Kinda thing that was available from your dealer.
I don't know much about it other than it's been discussed around here several times and I can confirm that my 86 305 TPI definitely had some very funky converter lockup behaviour at low speeds, similar to what you describe.
I think Vader or others would know more about it- and whether it's still available for you to try out.
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
Bert87
Aug 23, 2015 03:50 PM
db057
Aug 22, 2015 08:17 PM
Fronzizzle
Aug 9, 2015 01:15 PM
