have a question
Car: 1984 firebird trans am
Engine: 383 stroker
Transmission: th350
Axle/Gears: 10 bolt posi with 373 ring and pini
have a question
i was cheating out my block and came across the id number for the block said it was a 5.0 l69 is that a good block
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
It's a 5.0 liter (305 ci) block. Good or bad is up to you - personally I like my 350 better than my 305 - but it's all about what makes you happy, and not me or anyone else.
Engine: 383 stroker
Transmission: th350
im planning on putting a 350 in my 84 ta later down the road for now im going to stick with my 305 since its easyer on gas with prices the way they are
Car: 1988 IROC -Z28
Engine: 5.7L TPI
Axle/Gears: 2.77
I have had both powerplants, and I find that the 350 is a bit more friendly to me. I get great gas mileage around town...about 19 and 25 on the highway, but then again I have 2.77 gears. You'll be able to find more stuff cheaper for the 350, too.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
L69 is argueably the best 305 ever though, so don't compare it to a lame LG4 or TBI motor.
It's even better than a lame truck smogger 350, and so, better then most basic stock 350s out there.
Keep it, until it dies, or until you have the money to build up a proper 350.
Car: 1984 Camaro Z28 T-tops
Re: have a question
I definatly agree with Sonix. The guy that owned my car before I bought it blew up his 305 and slapped in a 350 from a truck and its slower on the top end than stock.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Car: 1982 Trans-Am
Re: have a question
oops, my bad, I assumed that block would be attached to the rest of the L69 motor - making it a tasty 305. If we're only talking about the block, then yea, same stuff different pile.
Then again, something may have happened since then, this was posted in November eh?
IIRC, matt(the guy with the crazy fast 305) uses a LG4 block..
