357 with no power
Old Nov 3, 2006 | 11:29 PM
fastTbird's Avatar
Car: 89 Firebird
Engine: 5.7 TPI
Transmission: 5 speed
357 with no power
I have a 89 TPI 357 fresh motor with 5000 mile and manual trans. It has a mild cam. The car has okay power at low rpms but when it hits about 4200 rpms starts dying and by the time it hits 4600 it has no power. It does have a rattle, chatter noise when the motor hits about 3200. I have the timing at 12 degrees. It's where the cam specs require. I have proper fuel pressure and no service engine light. I blocked off the egr system but still have the air system. I'm at a loss. Any ideas are welcome. Thanks.
Old Nov 3, 2006 | 11:49 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Well, With a TPI (assuming unmodded) dont expect to make any power over 4600RPM anyways. Thats about where they fall flat on their face.
The TPI's are good for gobs of low end torque but in stock form just fall flat on their face long before 5k
Old Nov 4, 2006 | 12:17 AM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
Although this chatter noise you are talking about has me concern..... What kind of noise? like a ping or something else like a lifter?
Old Nov 4, 2006 | 01:38 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
is the clatter at low RPMS, high gear, high throttle?
Isn't your timing set more by your computer? I mean, you still have knock retard? (working?)
5000 miles, does it burn any oil? What cam specifically? what pistons? What injection setup is that, MAF or MAP?
Old Nov 4, 2006 | 04:21 PM
BadSS's Avatar
It's not the TPI intake, they do not cause the engine to clatter and STOP pulling at 4600rpm. More than likely you need to go back through and reset your base timing (disconnect wire) and set to more like 6 - 8 degrees. Also set you min idle speed and double check the TPS voltage at idle and WOT. Wouldn't hurt to pull a couple plugs to see if you need to increase your fuel pressure. Check for vacuum leaks also.
83 Crossfire TA
Jan 3, 2016 01:26 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
sailtexas186548
Aug 24, 2015 10:11 PM
