milodon oil pan capacity??
Old Nov 4, 2006 | 03:01 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
hate do do this to you guys but it relates to a 68 mustange my roomate just bought. Its a 347 stroker with a milodon oil pan. He just bought it and changed the oil today. We got 3 gallons out......
The pan has no markings on it but i went to the milodon site and they only have 7 and 8 qt oil pans for engines this size. I cant find anything larger.
So we filled it with 2 gallons (8 qts) and its not reading anything on the dipstick. It is an aftermarket dipstick...maybe too short for this pan?
Old Nov 5, 2006 | 01:06 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Aftermarket 'sticks are usually junk. Put a factory one in there. I had a Mr. Gasket on that was off by 1/2qt compared to the factory one.
I can't remember though... does the 289/302 dipstick tube go in the block, or the pan? I think its the pan, no?
Old Nov 5, 2006 | 08:32 AM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Aftermarket pan and dipstick. They're not gonna jive. What you would normally do is fill the pan to capacity as recommended by the manufacturer then mark the new dipstick wherever the oil level is. It looks like you've probably got the wrong dipstick that doesn't reach far enough into the sump. The idea of the deep pans isn't so much to increase the fluid capacity of the engine as it is to get the oil away from the crank. Getting the oil down below the crank with a deep pan keeps the oil cooler, provides better windage and decreases aeration. 8 qts sounds like plenty of oil even for a deep pan. If you fill it anymore to get it to read on the stick you're going to have problems. Call Milodon and tell them what you've got. They should be able to tell you how much oil that pan needs. Fill it up with that amount and let it ride or find a longer dipstick.
Hotrodboba400
Dec 10, 2019 07:07 PM
BDR
Nov 7, 2015 03:05 PM
abray1
Sep 14, 2015 08:18 AM
timonator
Sep 13, 2015 11:49 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
