Whistling Noise??
Car: 89 trans am
Engine: 305 tpi
Whistling Noise??
Hey i have a 89 trans am with a 305 tpi, automatic. car was fine and i go and start her up and i'm hearing a pretty loud whistling noise.. it sounds like a tea kettle.. seems to go higher in tone and volume when the rpms start getting to 1,200-1,300rpm and then it gets drowned out by my exhaust.. i checked under the hood, idnt belts or alternator.. the noise hurt my ears when i put my ear toward the drivers side of the bay.. what could this be? a vacuum leak?
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
lets hope that its a vaccume tube come unplugged. loud whining noises that arent vaccum leaks are genereally not good.
Take a piece of heater hose, and stick it in your ear (it's not often I get to tell people to do that without hostile intent!!) and probe around with the other end of it to find the source.
Car: 89 Z28
Engine: 350 with ads
Is the sound definatly from under the hood?
Was your radio on? I had a case where i had a whistle from the speakers that was somehow effected by Engine RPM. (bad wires , interference etc). I did a tune and replaced teh radio and teh "whistle went away....
Car: 89 trans am
Engine: 305 tpi
its definately comming from under the hood... i checked my fluid and im good.. radio wasn't on, plus i know its good i redid all the wiring myself.. i guess ill try that heater hose idea
Car: 84 Z28
Engine: 305HO
Transmission: Borg Warner T5
Axle/Gears: 3:73
check the dust guard on the flywheel,mine was touching and there was an awfull squeeling noise,then hook really good now its fu#*ed.hahaha aw well there not very costly.
Car: 84 Z28
Engine: 305HO
Axle/Gears: 3:73
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
You know, if you're going to pull that BS, atleast find a thread where you can maybe throw in a helpful comment or two.
Anyway, my buddy had a loud whistle on his 91 and it turned out to be his throttle body. Never gave him any problems though.
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Time to go buy a $12 stethascope at vatozone and pinpoint the sound. If it is coming from that side, I'd still put my guess on the ps pump.
sjorgens
Oct 1, 2015 07:54 PM
