Fuel Tank Vent Valve
Car: 87 Firebird,
Engine: lq4
Transmission: gto t56 (mn12)
Im having a very hard time finding a fuel tank vent valve. Or maybe its called a fuel breather valve. I'm not sure and that may be the problem. On my fuel tank there are four lines coming out of the top of the tank. One of the lines ends with the vent valve being attached. I can't seem to find one anywhere. If anyone can find a part number or the exact name to look one up I would greatly appreciate it.
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
This thing?
https://www.thirdgen.org/forums/atta...082705-003.jpg
I found out that early Part# 10029752 was replaced by Part# 10033125
They are the exact same part just different colors.
GM Parts Direct: Your direct source for Genuine GM Parts
Car: check
Engine: check
Transmission: check
Re: Fuel Tank Vent Valve
Its main purchase is to allow air into the tank as fuel in consumed. Secondary function is to allow excess pressure to be relieved from the tank. This can occur if something happens to the CCP system.
RBob.
RBob.
Car: 1989 IrocZ
Engine: 421 Dart Stroker
Transmission: 4L60E Cahall Performance Built
Axle/Gears: Midwest Chassis Fab 9/ 3.55 gears
As far as I know the part is discontinued. Try the junkyard.
Car: check
Engine: check
Transmission: check
Also check 4th gens, some (all?) of them also use the vent valve. The hose connection is slightly different but it works.
RBob.
RBob.
