Stroker Oil Pan, Pump Suggestions
Old Nov 12, 2006 | 03:05 PM
km7152's Avatar
Car: 1991 Camaro Rs
383 stroker bottom end, 4 bolt block, 2 peice RMS...Gonna be using Hooker LT's and eventually a tubular K-member, dont want anything crazy just for street/strip use but want to keep clearance in mind. Anyway, best pan/pump/pickup for this application, hopefully not more than a couple hundred bucks.
Old Nov 12, 2006 | 06:01 PM
Damon's Avatar
I've always used stock pans on my 383s. They'll clear.
The stock pump and pick is hard to beat as long as you keep the pickup close to the bottom of the pan (1/4") and weld the pickup in place so it can't fall out.
Old Nov 12, 2006 | 07:20 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
I have the 6 quart moroso pan they make for our cars...I have one of there pumps and pick ups has well... Its theyre high volume high,high pressure pump..I have 80 lbs of pressure, but if I remember, the oil pan was 110, and the pump was around 90...
MoJoe
Sep 24, 2015 09:12 PM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
MY87LT
Aug 17, 2015 08:43 AM
gwade12
Aug 8, 2015 08:17 AM
