pick up coil replace on a 2.8 v-6
Old Nov 14, 2006 | 08:27 AM
elwoodbdr's Avatar
Hi, quick question, For some reason I have seen two sets of directions to change the pick up coil in my car, one says, remove cap, rotor, then remove clip holding pick upo coil and replace, Another said you have to remove the distributor? I do not see why it needs to be removed? looks like I can do the first set of instructions, Am I missing something here? Anyone ever changed one on this car? Also what are the symptoms of a bad pick up coil and what is its job? Sorry for not knowing, I am not an expert on engines.
Old Nov 14, 2006 | 11:08 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The distributor shaft needs to be removed to access the pick up coil. So need to pull the distributor out. There is a roll pin on the lower gear that retains it to the shaft. Once the gear is removed the shaft comes out the top.
May need some carb cleaner (Gum Out) on the shaft to cut through the decades of hardened varnish.
When reassembling, the dimple on the gear lines up with the cut in the top of the shaft.
RBob.
Old Nov 14, 2006 | 11:46 AM
elwoodbdr's Avatar
Ok, thanks, If you say so I will go with that, however, I have the new part, and unless i am missing something once the clip on top is removed, wouldnt that coil just lift up? Reason I am asking is you mentioned I have to remove the distributor to access the coil? Mine is accessible as soon as I take the distributor cover off, its right on top, I enclosed a picture of my part, you will see there is no area for a pin? just a round piece with a wire connector and the piece goes over the top and is secured with a C clip
Attached Thumbnails pick up coil replace on a 2.8 v-6-mvc-044s.jpg   pick up coil replace on a 2.8 v-6-mvc-045s.jpg
Old Nov 15, 2006 | 08:19 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Head out to the car and pull the cap and rotor off the distributor. Note the star wheel on the shaft. The coil fits below that piece.
Also pick up a new rubber O-ring. It goes onto the distributor housing right below the mounting flange. These always dry out and start leaking.
RBob.
Old Nov 15, 2006 | 08:46 AM
elwoodbdr's Avatar
ok, so just to be sure then, I still have to remove the distributor? Sorry to be a pain and ask the same question again!!
Old Nov 16, 2006 | 07:47 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
yes!
Old Nov 16, 2006 | 02:41 PM
elwoodbdr's Avatar
Well, I will be attempting it this weekend, I even have the official pontiac mechanics book on this car, My coil is under nothing , there is simply a clip that pops off, then it looks like it lifts right up, I dont see where taking the distributor out is neccesary, because there is nothing over the coil, but I will let you know if I had to remove or not, I have the v-6 with a separate ignition coil, mine is not in the distributor. Thanks!!!
Below Average J
Members Camaros
23
Nov 18, 2015 10:03 PM
TheExaminer
Aug 25, 2015 07:34 PM
db057
Aug 22, 2015 08:17 PM
Bryan F
Aug 18, 2015 02:28 PM
