What size injectors should be used with an L98 383 build?
Subscribe
Nov 21, 2006 | 09:47 AM
I'm building a 383, and looking out of my L98 for a 1990 vette.
I need to pick up some new injectors.
I'm looking for recommendations and trying to determine what lb. rating i need?
Compression 10.1
Heads = 113 heads ported
Cam = 224/232, 114LSA
Superram, AS&M runners, eddlebrock base, hedman elite headers, true dual exahaust, borla xr-1 mufflers.
My engine build thread is here.
https://www.thirdgen.org/forums/tech...endations.html
Any recommendations for injectors?
Reply 0
Nov 21, 2006 | 10:41 AM
30-36lb SVO injectors.
Reply 0
Nov 21, 2006 | 01:10 PM
24's
Reply 0
Nov 21, 2006 | 01:11 PM
Here is a link to the math... you can go to the bottom of the page and use their calculator. I recommend that you be honest with you hp calculations/estimations. I like to run the calculator a couple times using different BSFC to get a "reasonable" range.
http://www.rceng.com/technical.htm
Reply 0
Nov 21, 2006 | 01:13 PM
With a 383 and a SuperRam I would go with 30lbs.
Reply 0
Nov 22, 2006 | 09:38 AM
Quote: 24's
why 24?
all the calculators say between 30 and 36.
I found these two links
http://www.venom-performance.com/nf/...niInjector.cfm
24lb are good for 310 hp.
30lb are good for 385 hp
and here is another injector calculator(at the bottom of the link)
http://www.fbody.com/calc.htm
here is another thread asking the same question.
http://forums.corvetteforum.com/show....php?t=1554661
It would appear there are a lot of people using the 24lb injectors by SVO. But I'm scared of that minimal HP rating...........it would seem you would have to be exceeding the recommended 80% duty rating in order to make much HP.
I'm leaning towards 30lb or 32lb at this point.
Reply 0
Nov 22, 2006 | 01:49 PM
I used that stupid math equation and i over fueled my engine.
Reply 0
Nov 28, 2006 | 12:56 PM
give me some more info on your exp. It would help me in my build and purchases i'm making this week.
Reply 0
Nov 28, 2006 | 05:27 PM
36-42, not sure why people are so scared to go with a bigger injector as long as you have a way of programing you own computer, hell there are V6 guys on here running 60Ibs with no problems.
Quote: I used that stupid math equation and i over fueled my engine.
How do you over fuel you engine
Reply 0
Subscribe
