Where to mount A1000 pump
Old Nov 23, 2006 | 04:23 AM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Looking under the car I cant seem to find a good place to mount this. I dont think I would trust sheetmetal screws, it needs to be as close to the tank as possible right?
Old Nov 23, 2006 | 10:14 AM
Take out the back seat and lift the carpet; use bolts and nuts through the body behind the seat cushion.
Old Nov 23, 2006 | 10:44 AM
brutalform's Avatar
I have some pics of where I mounted mine. IIRC, I have posted these before. If the server will allow me to re-post them, I will.
Attached Thumbnails Where to mount A1000 pump-0250.jpg   Where to mount A1000 pump-picture-012.jpg   Where to mount A1000 pump-picture-021.jpg
Old Nov 23, 2006 | 10:47 AM
brutalform's Avatar
I was able to find 3 pics. Mine is mounted against the spare tire well. You can mount the pre-filter, and the out filter directly to the pump, but it depends on how close your exhaust system is to it. Just to be safe, I mounted my out filter to the side of the hatch bottom. It just needed some extra fuel line to do it, but, IMO, its way safer, and far from the exhaust system. You can reach in the spare tire well, and use nuts, and lock washers if you wish. This is what I did.
You are correct. As close, and lower than than the fuel tank. This is explained in the instructions.
Be sure to buy the correct "O" rings from Aeroquip. Regular "rubber" rings will not cut it. You will need them for the the pump, and filter fittings. the rest of the lines will use regular AN fittings.
Make sure you use the line sizes that Aeromotive recommends.
Is this a carb, or EFI application? If EFI, I have some important info for you.
Old Nov 23, 2006 | 05:17 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Thanks, this is carb right now but will be efi in the next year.
Old Nov 23, 2006 | 06:03 PM
brutalform's Avatar
You're welcome. I was just asking, because, if it were a TPI, the factory rails would have to be addressed, or you would have too high of a fuel PSI.
Old Nov 24, 2006 | 03:50 AM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
I was going to use the stealth ram so I couldnt use the stock rails anyway, but by any chance do you know if they would be ok for 650hp? Also it looks like I may have screwed up, I want to run E85 in the future and Ive heard the A1000 wont hold up to ethanol.
Old Nov 24, 2006 | 03:59 PM
brutalform's Avatar
Its really not the rails, but, the factory lines, and regulator. There is a "sharp" bend in the factory lines, as it comes off the factory regulator. This bend is sharp enough to restrict the fuel to raise your fuel pressure. I removed all the factory junk from my rails, welded the holes shut, and ran some -06 AN fittings from each end of the rails. Then I also used the Aeromotive regulator. I set up the whole system to run like this.
https://www.thirdgen.org/forums/tpi/...pump-pics.html
Orr89RocZ
Apr 25, 2016 08:28 AM
z28_AJ
Aug 27, 2015 08:59 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
