I NEED 2.8 OR 3.1 IRON HEADS FOR 90 FBIRD
Old Nov 24, 2006 | 03:36 PM
90fbird3.1's Avatar
LATE 80'S MODELS WILL WORK AND WHAT IS DIFFERENCE BETWEEN 2.8 AND 3.1 THANKS
Old Nov 24, 2006 | 05:32 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
I have an old GM V6 racer's manual that sites no differences between 86-92 60 degree Chevy V6 engines if equipped with TBI or MPFI in Camaros, Firebirds and S-10/S-15 pickups.
Stay away from the carbureted cylinder heads and camshafts.
Hope this helps!
Old Nov 24, 2006 | 09:19 PM
90fbird3.1's Avatar
thanks iwas told there is a difference but you probably right on the heads iwas told the diff. is 3.1 is stroked a liitle more or pistons not the same
Old Nov 24, 2006 | 09:47 PM
daves12secV6's Avatar
as long as u get heads from a 2.8/3.1/3.4 engine that is fuel injected they are all the same.
any heads from a non injected motor have smaller valves 85 and prior i believe
all the iron heads from 86-94or95 are the same no matter what engine they come from i.e 2.8/3.1/3.4 they all have the same casting number
Old Nov 24, 2006 | 10:26 PM
90fbird3.1's Avatar
Hope this helps!
i also heard that 3.1 90 model fbird came with double valve springs. doews that mean one spring with a damper spring inside?
InfinityShade
Feb 21, 2016 01:29 PM
italiano67
Aug 31, 2015 06:04 PM
InfinityShade
Aug 22, 2015 08:00 PM
okfoz
Aug 21, 2015 07:38 AM
