Lifter Rattle...???
Old Dec 2, 2006 | 12:42 PM
kenf729's Avatar
Car: 1989 Camaro RS, 355, holley 650dp
Engine: flow master headers, 3" exhaust
Axle/Gears: stock
Lifter Rattle...???
Ok, so here's the deal...
69-79 350 4 bolt main block, .040, stock cam, stock crank, flat top pistons, new lifters, 416 heads (stock).
I've got a bad ticking from the top of the motor, sounds like valve lash, but then I've adjusted so tight that the exhaust would stay open and back fire thru the exhaust...
Anyway I re-used push rods, springs and rockers, do you think maybe that I either have a bent pushrod or weak spring? any help would be appreciated.
Ken
Old Dec 3, 2006 | 03:11 PM
kenf729's Avatar
Axle/Gears: stock
Bump...anyone?
Old Dec 3, 2006 | 03:26 PM
JDSimpson's Avatar
Car: 86 Z28
I had a 350 that did that. I put a new cam and lifter set in it and it still made the noise. I drove it one day and it made a loud pop and started stuttering. I thought it was a collapsed lifter. I got it home and took the valve covers off and it was a broken rocker. Put a new set of rockers on and it was fine. No noise at all.
Old Dec 3, 2006 | 06:14 PM
kenf729's Avatar
Axle/Gears: stock
hmm. new lifters and cam, so I wonder if I got a bad set of rockers,,, cheap to try anyway...any other thoughts?
Old Dec 4, 2006 | 06:31 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Thats call detenation, run higher octang fuel or turn your timiing down to around *10
Your fuel is sparking off to soon making it slam valves shut and they rattle almost like a dielse. higher octange or less timing is your only fix.
Old Dec 4, 2006 | 06:51 AM
BadAssNovas.com's Avatar
Car: 74 Nova
Engine: 383
Transmission: TH350
Could be a wiped cam lobe. Spin your motor over by hand and watch the rocker arms closely. Do you see one that is moving a lot less than the others?
Old Dec 4, 2006 | 11:57 AM
kenf729's Avatar
Axle/Gears: stock
Gumby, my timming is currently set to about 2 - 4 degrees, it sounds like a bad lifter just a lot of ticking...
BadAssNovas.com, my cam is new, right out of the box... but I can look to see if there is any less movement of rockers...
Old Dec 4, 2006 | 12:09 PM
Car: 74 Nova
Engine: 383
Transmission: TH350
New doesn't mean anything. It still could have wiped a lobe. A ticking sound could also be a header leak.
Old Dec 4, 2006 | 01:43 PM
kenf729's Avatar
Axle/Gears: stock
Point taken, but can you explain the wiped lobe part...as well I just installed headers with new gaskets, so not sure there is a header leak, but I'll recheck them...
Old Dec 4, 2006 | 02:27 PM
Car: 74 Nova
Engine: 383
Transmission: TH350
I've broke-in a new cam correctly from a very popular cam manufacturer and it ended up wiping an exhaust lobe in a month. Turned out to be a flaw with that batch of cams.
If you just installed new headers and gaskets, you need to re-torque the header bolts after a few heat cycles. That might be the source to your problem right there.
Old Dec 4, 2006 | 02:36 PM
kenf729's Avatar
Axle/Gears: stock
thanks, I'll do that tonight. really appreciate the advise...
Old Dec 4, 2006 | 02:40 PM
Car: 74 Nova
Engine: 383
Transmission: TH350
Glad to help...hope it's something simple as the header gaskets/bolts
Old Dec 4, 2006 | 02:41 PM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Im with gumby.
Id take in account that your running 58cc heads. I am
running 081's 58cc heads as well on my L98. It seems to
me my motor is alot more prone to detonation if timing
is too advanced or low octane fuel such as 87.. I run
premium 100% of time without a problem on stock timing.
Plus! The car is faster than it was with the old L98 heads
tyeo098
Nov 30, 2015 06:27 PM
codeysabatini
Nov 10, 2015 04:07 PM
skinny z
Oct 5, 2015 06:23 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
dimented24x7
Sep 6, 2015 03:51 PM
