Running RICH
Old Dec 11, 2006 | 07:17 PM
buell0303's Avatar
Car: 91 V8 Camaro rs and 03 v6 mustang
Engine: 305 V8 TBI
Transmission: Manual 5 speed
Axle/Gears: stock
Running RICH
My camaro is running really rich and can't even drive it cause it so bad. I noticed the return line is pinched a lil bit. would this cause it to build up to much fuel pressure. I looked at the injectors and they are not misting but pouring fuel in a cone patern. do you think if i change the injector that it might solve the problem. I had it running fine the other day and then washed the engine and it started doing this.
Old Dec 11, 2006 | 08:29 PM
Gramps's Avatar
Car: 87 Camaro IROC
mayb check your fuel press, if its more than 42psi then that could be the problem, if its not then you can look at the TPS sensor, do a search on this forum or on google for properly calibrating the TPS sensor (all you need is some wire and a voltmeter)
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
tmellott89
Aug 16, 2015 02:58 PM
squiggy2
Aug 9, 2015 09:30 PM
