454 rebuild
Old Dec 13, 2006 | 11:18 PM
Fromaster's Avatar
Car: 86' camaro
Engine: 305 (currently swapping 454)
Transmission: 700r4(currently swapping th400)
Axle/Gears: stock
454 rebuild
hi im a cheap *** ******* who dont wanna spend money
i got a 454, and i want to rebuild it, its is even plasuable to reuse the main, and rod bearings? and just swap the gaskets and piston rings?
wow certain people with sunburnt below-the-hair-area is censord
Old Dec 14, 2006 | 12:23 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Don't expect it to last.
It really depends on what kind of condition they are in. The biggest parts cost in any rebuild is the bearings. I'd never put old bearings back into an engine.
If you're doing a cheap rebuild, you won't even need to take the crank out. Pull the rods and pistons, put new rings on and slap them back in.
A rebuild like that may last a year or 2 if you're lucky. Spend the money and do it properly the first time. The only way you could reuse the old bearings is if you were to mike everything to check all the clearances. If the bearings looked ok and clearances were within the tolerances then they possibly could be reused. I really doubt you will have the tools to do those kind of checks.
Old Dec 14, 2006 | 12:29 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
oh, yes, red-neck is censored... Not that it needs to be in your case, if you feel comfortable calling yourself that, by all means...
No, the bearings should never be re-used. They're kinda pricey up here, but summit brand bearings are about $12 a set, even with all the fees tacked on and border charges, its still half the price of buying them locally.
You can also get a full on gasket set (at least for SBC) for $30, **which includes head gaskets**. No idea how they can charge that little for it, since head gaskets are $50 per side up here.... Shrug, worth mentioning at least.
You know all that is involved in a big block swap into your 3rd gen?
Old Dec 14, 2006 | 09:06 PM
Fromaster's Avatar
Car: 86' camaro
Axle/Gears: stock
yes i am determined no mater what to get it in there, everyone says to me "pat, its not gona fit" and i say "it will, and if it dont im renting a welder"
plus david t (if you have heard of him) doubts that it will work so i must prove him wrong
Old Dec 14, 2006 | 09:11 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Just tell them to go look at the pictures on my web site. My 540 fits although my car can never be street legal again.
Old Dec 14, 2006 | 09:53 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Build the bottom end right the first time and it WILL cost you less in the end.
Old Dec 17, 2006 | 09:56 PM
Fromaster's Avatar
Car: 86' camaro
Axle/Gears: stock
if i got one of those rebuild kits from summit with the stock sized main and rod bearings, do i still have to get the crank and rods machined?
Old Dec 17, 2006 | 10:53 PM
Air_Adam's Avatar
Get the crank checked first, have it ground if needed, then get a kit with the proper sized bearings for the crank you got back.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
hartsmike
Oct 2, 2015 07:11 AM
Derrick86
Oct 1, 2015 05:12 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
