ok so now i got me a cam
Old Dec 17, 2006 | 12:50 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
alrite i bought a cam for the 305 and i was wonderin if i need to do headwork to my head b4 i can install the cam or not. heres the link to the cam. http://store.summitracing.com/partde...5&autoview=sku and here is my heads casting number 14014416
Old Dec 17, 2006 | 03:15 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Im running a set of 416s myself with a comp XE268 .477/.488 lift (@ valve) without having to cut the valve guides.
I would highly suggest ditching the stock springs for some matched to the cam though.
Also due to casting variances you should double check every valve for clearance once its all together. Even on the same head some can have tons of room and others will be tight! Who knows, even with your lift you might have a couple valves hitting the guides...
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
