Deleting Smog Pump Need Belt Size
Old Dec 26, 2006 | 04:02 PM
kuulkatdadieo's Avatar
Car: 1989 Pontiac GTA
Engine: 350 5.7 T.P.I.
Transmission: TH 700-R4
I have a 1989 Firebird with 350 tpi. And i was wondering why do i need a longer belt(986k6) if i am taking my smog pump off. Do i need a longer belt or shorter and i did read the tech article and iam confused.
Old Dec 26, 2006 | 06:04 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
It takes a longer belt, I have a under drive crank pulley and I centered the tensioner in it's travel and used a piece of string to get me close on the length. And I still had to make about 4 trips back and forth to the parts place before I got the right one, 1" length makes a big difference, seems like I ended up with about a 94" or 95" belt.
Old Dec 26, 2006 | 07:48 PM
Thanks man but iam still confused if i should buy a shorter one, like a 93.5 because wouldnt it make sense to do that since iam taking a pulley off. I know you have to route the belt a different way and did get off this website. Under crank over water under power steering over alternator and finally over the a/c compressor. If this correct maybe iam getting somewhere. As this demonstrates. But, the tech article says i need a 98.6.
Old Dec 26, 2006 | 09:02 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
The difference in the length is because you are changing the routing, and thus changing the length. Without the SP, the belt wraps differently, taking a longer path.
HOWEVER - I found that with mine, I needed an entirely different size than was listed in the tech article. You'll have to play with a few maybe to get your desired length, routing, and tension.
Old Dec 26, 2006 | 09:13 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
I have removed the smog pump on my 89 RS, the belt # for gates is K060980, i had to re route the belt of course.
Old Dec 26, 2006 | 09:26 PM
Thanks i found out that the belt you list is 98 5/8 in. long. Which is close to the tech articles 98.6 in. If your 89 RS has a 350 then it should be a perfect match, correct?
Old Dec 26, 2006 | 09:29 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
I have a 383 with carb, was tbi, I believe the serp system is the same as tpi that i know of.
Old Dec 27, 2006 | 05:34 PM
Thanks man i just picked up a belt that is 96.7 in. at AutoZone and i will give a shot tomorrow and i will let you guys know how it turns out.
Old Dec 28, 2006 | 01:00 PM
I tried to take the pulley off, but one of the three bolts is stuck and it wont come out so i just installed everything back on i guess i will have to live with my smog pump. I left the belt on and tried to take the bolt out but their isnt enough tension on the pulley to keep it still. Any suggestions would be great.
Old Dec 28, 2006 | 07:57 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Wait untill the pump locks up tight and melts a belt into, then the pulley will be tight and the screws will come out easy. Thats what happened to me anyway. Or find a big strap wrench to hold the pulley.
Old Dec 29, 2006 | 02:28 PM
Thanks guys i finally got the dumb@#$ thing off. I was about to strip out those Torx bolts but i hammered my Torx socket in it and finally got it off man im i lucky that could have been really bad. Why does GM have to use those dumb star bolts they really **** me off. Anyways thanks and should find a right belt for that thing as 98.6 was too long and 96 was too short im going to hit right in the middle. THANKS and HAPPY HOLIDAYS
Frozer!!!
Jan 19, 2024 04:55 PM
italiano67
Dec 11, 2016 09:21 AM
toronto formula
Nov 10, 2015 06:17 AM
actionj
Carburetors
Aug 16, 2015 09:51 AM
knight72
Aug 10, 2015 09:32 PM
