swapping to 9" means shorter driveshaft?
Old Dec 26, 2006 | 05:36 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
When swapping to a 9" would the driveshaft need to be shortened or will I get away with my factory length one? I know I'll need a conversion u-joint at least if I keep my factory length custom aluminum one.
Old Dec 26, 2006 | 06:29 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
I think the stock one with the u-joint will work napa-427 I think is the part number for it.
Old Dec 26, 2006 | 08:28 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Depends what yoke is on the 9". Some yokes are longer than others.
TheJoeY88
Dec 31, 2016 07:30 PM
evilstuie
Feb 28, 2016 03:33 PM
theshackle
Aug 23, 2015 03:49 PM
Cleotiz
Aug 22, 2015 01:54 PM
