Does this sound like I am running out of fuel?
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
I have a L05 (350 TBI) with BBC injectors in a car that was originally an L03. I realize that lack of power up top is to be expected from a motor that was designed for stump pulling, but this thing REALLY falls on its face around 3500, maybe 4000 RPM. It literally stops pulling completely, especially noticable in 1st gear. I probably have the original fuel pump, and the car has 172,000 miles. Have I likely taken this pump as far as it is going to go?
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Engine: 400 sbc, miniram, fast burn heads
Transmission: art carr 700r4
Axle/Gears: 3.54.s
get a fuel pressure tester, a wise investment, specially if you are into tweaking with your rig and it sounds like you do. get the tester and end the fuel guessing games.
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
BBC Injectors are 90# per hour injectors. I have an EBL set up with a custom PROM that I am constantly tweaking. I have a fuel pressure guage, but no way of looking at it from inside the car. I guess I should get a different one then and check it that way.
Car: 1983 G20 Chevy
Transmission: 4L60
I have run nearly stock TBI engines to 5,000 rpm easily when they are tuned properly.
I think the bottle neck is the original LO3 exhaust manifolds. There is power to be had even with a stock L03 in the exhaust.
Here is a screenshot of the Datalog of the internally stock 4.3 TBI that is in my brothers 1992 Chevy Astro work van. Loaded with about 1,000 lbs of tools at that.
https://www.thirdgen.org/forums/atta...z4-cam-wot.jpg
https://www.thirdgen.org/forums/atta...mph-cruise.jpg
This one is falling on its face at about 4,200 rpm due to fuel issues. The original 200,000 mile Delco fuel pump is probably on its last leg.
The engine is stock with the exception of Edelbrock TES headers, a 3" high flow cat, 3" single exhaust, and 1.6:1 roller rockers. Stock 3.23 gears.
92camaroJoe
Aug 13, 2015 06:07 AM
