correct way to install distibutor
Old Jan 6, 2007 | 07:09 PM
89jim's Avatar
OK need a little help here.It is almost time to drop my new engine back into the car. What is the correct way to re install the distributor. Motor is now a 383 but that should not make a difference. Thanks guys
Old Jan 6, 2007 | 08:13 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Bring #1 up to TDC + your base timing. If you want 8* of base then bring it up to 8* BTDC. Put the cap on the distributor and pick a terminal that you want to make #1. Mark the location of the #1 terminal on the distributor housing. Take the cap back off, drop then distributor and line up the rotor with the mark on the housing. Snug it down and put the cap/wires back on. Fire it up and put a light on it. It'll be close but you'll have to dial it in with the light.
Old Jan 6, 2007 | 08:32 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
Dialed in has you all dialed in.
Old Jan 7, 2007 | 12:21 PM
89jim's Avatar
What do most people use as a base ?
Vintageracer
Jan 10, 2020 05:33 PM
mustangman65_79
Car Audio
Sep 30, 2015 09:37 PM
fasteddi
Sep 2, 2015 10:29 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
